Anyone running an MX5 Plus Tallboy bar under a hardtop?
mazmad
Postby mazmad » Thu Oct 25, 2012 2:07 pm
Any fitting issues?
Re: Anyone running an MX5 Plus Tallboy bar under a hardtop?
Postby Magpie » Thu Oct 25, 2012 2:22 pm
No issues, however it would be worth putting a piece of high density foam on the top of the bar in case it rubs.
Hjt
Postby Hjt » Thu Oct 25, 2012 3:23 pm
Mitch has it fitted . It rubs however
mazmad
Postby mazmad » Thu Oct 25, 2012 8:33 pm
Thanks guys. Worth it from what I have heard for the added rigidity, otherwise not fussed (although hoping for some extra insulation from the sun, with my 'heater-always-on-issues' right now) .
I am putting an NA lid on an NB8B. That works right?
mrpham
Postby mrpham » Thu Oct 25, 2012 9:18 pm
I've got this combo and no real issues with fitment, it is true that it rubs slightly. I used some double sided tape to attach some foam on the hardtop where it touches and hasn't caused any problems since.
Current Forum Specials!
PaulF
Postby PaulF » Thu Oct 25, 2012 9:19 pm
mazmad wrote:Thanks guys. Worth it from what I have heard for the added rigidity, otherwise not fussed (although hoping for some extra insulation from the sun, with my 'heater-always-on-issues' right now) .
Are you suggesting that the hard top will increase your chassis rigidity? There's no evidence at all that it helps in that respect, and I've seen posts from those involved in the development of the car who said they tested it and there was no significant difference. It might stop a few rattles (or it might make a couple more). Will give you some shelter but the car will heat up if you leave it parked in the sun and you can't just drop the top to get rid of that hot air.
The NA hard top will fit on an NB8B, yes.
mazmad
Postby mazmad » Fri Oct 26, 2012 7:32 am
With respect to rigidity - that is what I have been told, yes. Some drag benefits too.
Postby hks_kansei » Fri Oct 26, 2012 8:57 am
mazmad wrote:With respect to rigidity - that is what I have been told
The hardtop is attached via 2 clips at the front, that do have some play in them by design.
There's then two more at the sides, exactly the same.
Then there's two rear catches that again, have quite a bit of play.
Then you also consider that a hardtop is only fibreglass, and can be flexed by hand a good 10mm either way.
Any chassis rigidity increase is going to be a placebo effect, generally because it's a bit quieter with the top on.
There are also people out there who swear that there's more chassis rigidity when the softop is up.
Postby Magpie » Fri Oct 26, 2012 9:03 am
hks_kansei wrote: There are also people out there who swear that there's more chassis rigidity when the softop is up.
There are other people who swear when they can't get the adjustment just right on the hardtop to stop the wind noise :)
mazmad
Postby mazmad » Fri Oct 26, 2012 9:46 am
Basically a lot of swearing going on then. Sounds about right.
Rocky
Concerned Citizen.
Postby Rocky » Fri Oct 26, 2012 10:56 am
Increased rigidity with a HT fitted makes no sense.
Other than maybe wind noise, you get more noise than you eliminate.
(noisy with the softtop, noisy with the HT, just noisy)
Cooler in summer for sure with the HT. Wind down the windows and the heat is gone in a flash.
Postby hks_kansei » Fri Oct 26, 2012 11:01 am
Rocky wrote:Increased rigidity with a HT fitted makes no sense.
Pretty much.
The softop is awful in summer, the black vinyl just acts like a great big radiator of heat.
mazmad
Postby mazmad » Fri Oct 26, 2012 11:10 am
Tell me about it.
Anyhoo...back to the original thrust of the thread: some padding and I am all good.
Zcootz
Postby Zcootz » Tue Oct 30, 2012 7:02 pm
What's the soft top doing up in the summer anyway ????
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Users browsing this forum: No registered users and 216 guests
