1.8 Build specs. PLEASE CRITICISE!!!
Re: 1.8 Build specs. PLEASE CRITICISE!!!
Postby NitroDann » Wed Oct 24, 2012 11:52 am
Just do 11:1, buy a drum.
Fill 90% with pump E85, water it down to E70 (E70 is the lowest the servo goes in winter). This way you will always have a consistent mix and never end up with a shortage of ethanol in your fuel.
Go to dyno.
Buy fuel a couple times a year.
Profit.
Dweezle
Postby Dweezle » Wed Oct 24, 2012 12:01 pm
Yeah i get that part. Good idea for safety!!
My issue is when i am halfway to Tamworth for a HILLCLIMB weekend and need to fill up with E85 i will be screwed.
Would be awesome if i could just trailer it.
Living in an apartment in the city does not really allow this though. :frown:
Reading as much as possible on MT.net and it appears, well according to SAV anyways, that say running 8.6:1 actually creates more torque and horsepower as you can run higher Timing then say 9:1.
It all gets very confusing going through everyones varying opinions!!! :?
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby hks_kansei » Wed Oct 24, 2012 12:02 pm
Doesn't fuel go off though? (Ie: It's Octane drops over time)
Not to mention it's maybe not too safe/legal to store a 200l drum of fuel (unless you've got land)
sailaholic
Postby sailaholic » Wed Oct 24, 2012 12:27 pm
Just get a head job! Won't that let you make more power at less boost, lag and detonation?
Postby NitroDann » Wed Oct 24, 2012 1:18 pm
What sav says is correct for 98, which is why 11:1 not 12.5:1 for E85 is also correct, he will say 11:1 or 11.5:1 if you can find his E85 posts.
You are allowed to store petrol of course. You can also run dual maps and run its wastegate wired open on 98 to the track or daily.
Or ms3 and flex fuel it.
Either way compression, big turbo and E85 is the answer.
Sean
Postby Sean » Mon Oct 29, 2012 5:49 pm
NitroDann wrote:get it tuned on e70.
Achieve this buy purchasing servo e85 and then diluting it down to e70 in a barrell.
This way you guarantee that you ALWAYS have the right fuel mix and do not have to buy 400 dollar drums of sucrugen.
Where are you getting your E85?
I've found it's solid E70 everytime i buy EFLEX at charlestown - Seems they have kept the winter 70% for over 18months now.
(yes I've tested every batch I've bought).
Dweezle
Postby Dweezle » Mon Oct 29, 2012 5:58 pm
That is interesting.
I have heard a similar story from a few people.
I wonder why??
still, on the compression ratio front, no one i have spoken to has been able to say with certainty what i could run on 98 octane.
Has everyone here, if they replaced there pistons just dropped to say 8.6:1 or is there anyone here aiming for say 300hp running higher?? Eg-9.5:1.
I am terrified that going so low will make the car really dead off boost.
Jeremy Clarkson
Postby NitroDann » Mon Oct 29, 2012 6:05 pm
9:1 in the Tubular T28 SE here, it was ok with the wastegate wired open, slow but not silly slow.
Sean
Postby Sean » Mon Oct 29, 2012 6:07 pm
There are quite a few guys hapilly doing 98 into 10:1 engines.
It's a balance, if you're really worried, run down at 9:1 and more boost, remember though a well designed MX5 turbo wont be a dog off boost, because you can be making respectable boost from super low in the rev range.
Postby NitroDann » Mon Oct 29, 2012 6:14 pm
Also charlestown. Ive never tested it, I just get the laptop and retune whenever the car doesnt seem spot on.
But my car is on e10 right now cos it has a stock engine and no ecu.
project.r.racing
Postby project.r.racing » Wed Oct 31, 2012 9:06 am
I mainly deal with Astinas and Lasers mostly. Recently most owners have started moving away from the regular 8.2:1 pistons you find in early BPTs from Familias. And now using 9.0:1s. On most setups, the boost has been coming on 500-700rpm earlier.
Old skool BPTs (8.2:1) full is about 32-3500rpm. On the 9.0:1s, full boost as been about 25-2700rpm. And the only change as been the pistons. All running on 98 pump fuels.
Dweezle
Postby Dweezle » Wed Oct 31, 2012 9:11 am
Thanks for the heads up.
That is exactly the kind of data i was after.
So 9:1 seems to be the spot?
I could/will run Water injection or E85 at events to run higher boost.
I was hoping i could get away with 9.5:1 but that may be pushing it and i do need it to be safe.
Jeremy Clarkson
project.r.racing
Postby project.r.racing » Wed Oct 31, 2012 10:22 am
Nothing worng with going higher that 9.0:1. As long as good fuel and a good ecu are used.
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Wed Oct 31, 2012 11:03 am
Im on the same boat Dweezle,
Im tossing between 9.0:1 or 10.9:1 they are my only options atm in a 84.5mm piston. I would have went with 9.5:1 if I had the choice though but I think ill just settle for the 9:1 as it will give me some more room for det
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
