Converting early NA6 rear number plate panel to later model
Mr nanotech
Re: Converting early NA6 rear number plate panel to later mo
Postby Mr nanotech » Thu Oct 18, 2012 4:53 pm
lee wrote:I reckon it's way too strong at the top and not nearly strong enough at the bottom, and you can still see points of light from the LEDs. You're onto a winner though!
THats because there are no leds on the bottom.. it's a reflection. THey'd have to have a lense over them in my opinion it's waaaaaaaaaaay too bright and looks gross when you can see them.
lee
Postby lee » Thu Oct 18, 2012 4:56 pm
that's why I suggested a diffuser ;)
'91 Roadster
Postby Mr Morlock » Thu Oct 18, 2012 7:54 pm
there is nothing complicated about this. A standard Lc lamp is incandescent and the light output is modest. The LC lamps themselves have a lense designed not to dazzle but to provide sufficient light to read the licence plate. The strip LED shown is merely far too much light for the application. Lightiing on the rear of a car is meant not to distract other motorists. You can readily purchase ADR approved LP lamps. Hella and Narva offer these lamps.
CarbonMiata
Postby CarbonMiata » Sun Oct 21, 2012 5:29 pm
Yeah I agree with all the comments. Those LED are far too big and too bright. I am looking for an other solution and will report back ASAP!
I am trying to listen to people ideas/suggestions/complains as much as I can so thanks a lot for the feedbacks. :NA8:
PaulF
Postby PaulF » Sun Oct 21, 2012 5:32 pm
Hey Marc, I appreciate your input on this. If you get a nice LED setup then that would be perfect for those like me who want to get a different design to what came stock on their car. :) Looking forward to seeing what you come up with.
