I weight 94kg.
Pure muscle too, you need it for the clutch and steering !
Id be willing to wager that a driver only roll hoop with the drivers seat on the floor, or better yet, bolsters welded to the floor and a expanda-foam seat on that there would be only a head above the doors. Then add a fibreglass cover for everywhere but the drivers torso, so that air goes straight up the bonnet and over a flat panel instead of hitting the windscreen and with a wing mounted on normal APR raised mounts the drivers head would hardly affect the wing.
Combine that with a full flat floor, splitter and diffuser and Id imagine you would cut CD by 15% odd and frontal area by 25%.
And you would have proper, proper downforce.
Is there an adding lightness thread? Lightness racing mods
Re: Is there an adding lightness thread? Lightness racing mo
- Guran
- Vehicle: ND - 1.5
lightyear wrote: I am not light, and there are others that race these cars that are heavier than average, and there isn't much you can do about that, as it is just genetics. Rant about me weighing too much.........And i am not overweight.
Gotta admit that I got a shock when I saw you in person at Winton, Dave. Let's just say that I wouldn't be too keen to bump into you in a dark alley! Ever considered a career in stage wrestling?
Me? My "added lightness" is genetic. All 169cm and 67kg of it!
- Jeo
Guran wrote:Me? My "added lightness" is genetic. All 169cm and 67kg of it!
Pfft. Only 60kg here
Alo, take a dump *before* you go out on track...
- cooper1896
nanotech wrote:Wonder how much Dann weighs and if he wears speedos driving. Pedal rubbers seems abit extreme. You could probably lose that weight with a hair cut
hahah!
Andrew Cooper
White Na8 Clubman
White Na8 Clubman
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
I don't consider myself as big, i was lucky to get the small genes in my family. Little brother is 6'6" and about 100-105kg's, and my older brother is 6'8" and about 95-100kg's. Good friend is 6'10" and size 17 shoes . So at 6'2" not so big relatively. At least i can fit in an mx5 with a helmet on (with no seat rails).
NitroDann wrote:I weight 94kg.
Bump (by 6 months )
Where do you get a cf roof?
- PaulF
You do a CF hard top dance and summon the gods to pester Lightyear until he makes a batch.
- rain902
Sure enough, but what class would you be able to compete that in? GT Cars?
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Personally I dont really care for classing at this point, I just want the fastest cheapest car possible.
Which is why the US system works so well.
You take a cars power and weight (verified via weigh bridge and independent dyno).
You then take the power and weight and assign points based on this (200hp/tonne might get 25 where as 300hp/tonne only gets 15 points).
You then list every mod imaginable and assign points to it.
Slicks are 8 points.
Unlimited bolt on aero is 12 points.
Coilovers are 6 points.
swaybars are 2 points etc.
This way you just build a car, and get slotted into a group based on how many points you have left, this way you can find out if the mods you have chosen are competitive, its great for development and allows people to spend 30k on drivetrain to do 1.07 at wakefield or 5k on aero/tyres to achieve the same thing.
Specifically regarding added lightness its sometimes cited at events that someone who has a fully stripped car should be immediately put into a racecar class. Well taking the windows out of their street car is the sacrifice they made, why shouldnt they be rewarded for it? Its a free mod, and thats what makes it excellent, and thats not even questioned in the US its just part of the power/weight equation.
- rain902
NitroDann wrote:Personally I dont really care for classing at this point, I just want the fastest cheapest car possible.
swaybars are so heavy. :shock:
- rain902
just a minor technical point - we aren't in the US and every cams class I can see doesn't subscribe to the methods as above.
If you aren't a trophy chaser it isn't important just show up to a club day and run the state times you can and be proud you did it for cheap.
- rain902
NitroDann wrote:If you aren't a trophy chaser it isn't important just show up to a club day and run the state times you can and be proud you did it for cheap.
i remember those days, club sprints are fun however if you wish to race then you have to build your car to a class and that class has rules. Unless its time attack, but thats not racing.
Users browsing this forum: No registered users and 247 guests
