Solid lifter for B6.....where to buy?
mrpham
Re: Solid lifter for B6.....where to buy?
Postby mrpham » Sun Sep 09, 2012 7:32 pm
When I was taking to Gary Stewart about my NA engine build he did mention that you can convert your hydraulics to solids and just get shims for them, so would be a cheap way to do a shim under bucket setup. I think he said you just take the HLA apart and remove all the stuffs inside or chock it up? I forget.
All his personal engine builds use hydraulics or hydraulics converted to solids.
Also you can get Toda products through Jesse Streeter because he orders them direct from the factory.
Current Forum Specials!
Postby manga_blue » Sun Sep 09, 2012 7:51 pm
I think deckers does the same thing. It all depends on what you're doing. If it's an 8000+rpm screamer then weight becomes a factor: 37g for MMD vs 50g+ for converted HLAs
project.r.racing
Postby project.r.racing » Sun Sep 09, 2012 8:35 pm
manga_blue wrote:
project.r.racing wrote:those MMD lifters are $47 shipping (including insurance) if anyone was interested. recieved email from seller today.
??? for 16 of them ???
lol @ me...
project.r.racing
Postby project.r.racing » Thu Sep 27, 2012 10:09 am
Arrived!
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Tue Oct 02, 2012 11:47 pm
mrpham wrote:I think he said you just take the HLA apart and remove all the stuffs inside or chock it up? I forget.
Have a read of this thread on how to convert your hla's to solids, good write up with pics
http://fordlaser.com/forum/viewtopic.php?t=44633
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
mrpham
Postby mrpham » Wed Oct 03, 2012 11:15 am
rxmx wrote:Have a read of this thread on how to convert your hla's to solids, good write up with pics
Awesome!
I think it would be a decent option, considering it's what Gary Stewart uses in his crazy NA builds. Obviously the increase weight over other solids hasn't concerned him. But you raise a good point project.r , it's quite a big weight difference.
project.r.racing
Postby project.r.racing » Wed Oct 03, 2012 3:22 pm
One big thing I noticed about converting HLA to solids. Is that back 5+ years ago, solid buckets cost like $500+, also it was much cheaper to convert the HLAs back then. Nowadays with solid buckets being so cheap, those become a better option.
