5 stud conversion and coilover questions
Re: 5 stud conversion and coilover questions
Postby hks_kansei » Thu Sep 20, 2012 9:46 am
aka_juffa wrote:wider tyres while retaining the height ratio. An example is a 205/50/15 tyre/wheel combo will give a total wheel/tyre height of 587mm, and a 225/50/15 combo gives a total height of 607mm, an extra 20mm.
Just remember that because the wheel is attached in teh centre, whatever total wheel+tyre diameter difference will be divided by 2 to get excess ground clearance.
so a 20mm larger diamter combo will give 10mm higher ground clearance (Since the other 10mm will be on the top of the wheel)
chino
Postby chino » Thu Sep 20, 2012 6:01 pm
ah good point there!
1989 na6 Electric Orange
2005 Evolution 8 MR Gun metal grey
Hoping the mx5 will be faster!
Sean
Postby Sean » Fri Sep 21, 2012 6:59 pm
Or carry a couple of blocks of wood in the boot.
If you need to pop the front up, just drive her onto the blocks 8)
Cheap, effective, and you can pretend you're McGuyver.
chino
Postby chino » Sat Sep 22, 2012 5:17 am
Sean wrote:Or carry a couple of blocks of wood in the boot.
Hahah and if I get pulled over? Wait.. When I do! Lol
Sean
Postby Sean » Sat Sep 22, 2012 11:48 am
Just be sure to pull up uneven, then act concerend, say "Oh this sucks, Oh wait, I have some wood in the boot I might be able to level her up with".
Again, the cops will hopefully respect your McGuyvery skills. :lol:
chino
Postby chino » Mon Sep 24, 2012 12:23 am
ahh sean your a cracker haha
Ill just throw some slabs of wood outside the window and make sure i pull up on it 8)
