charlie's na6
Re: charlie's na6
Update.
So i changed around the front supports a little. Just widened them. Seems better now. I also added supports to the side.. Exact same way as my front supports just with wire and eyelets. Splitter is really stiff now. Interested to see how the car reacts at speed and whether the 9mm ply will be thick enough to not flex a lot at 200kph. Might but another piece of 12mm ply and lay the top with fibre glass just to be sure its gonna hold good. Anyways atleast i now have a template.
Pics:
Pics:
Re: charlie's na6
My eyes, or is it not centred?
needs to move to the passenger side by about 20mm
and the driver's side bottom buckle needs to move to the passenger side by about 30-50mm
Re: charlie's na6
yeah probably not straight haha..
- plohl
Re: charlie's na6
looks good dude.... but yeah, i can see the off-centered nice.
Guys - you seriously don't get how awesome this car is until you sit behind for about 60km and see it boost away on the gas
plohl
plohl
Re: charlie's na6
plohl wrote::
+1
As good as this car looks in pics, it looks MUCH better in action.
Re: charlie's na6
Cheers guys it is a lot better when it's at the track
So all the aero is back off. Picking up some fiberglass and resin from work and I plan to put some plastic angle just in front of where the lip sits on the splitter to act as a diverter and make sure that air doesn't go between it. Then I'm gonna glass it all to stiffen it up and make it waterproof
Updates later in the week.
- Vehicle: NA6 - Turbo
Re: charlie's na6
Looking good charlie,
more WOT vids please
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Re: charlie's na6
U will be rewarded at the end of the week
Update:
So the other day when i was removing the aero again i noticed the lip wasnt sealed air tight against the splitter. Last thing i want is it going through the gay. So i picked up some aluminum angle, fibreglass and some resin and set to work.
I traced where the edge of the lip sits on the splitter and cut and bent the angle around it. Once glued down i started to lay the fibreglass. The topside is now done but needs cleaning up. Ill probably just resin the underside i think. Plan is for the air to hit the angle and dispurse up over the lip and bumper.. Sorta like a mini airdam.
Anyways heres some pics:
Update:
Re: charlie's na6
Update:
Yet again we have more problems.. So i replaced the crank and cam angle sensors trying to fix a problem ive been having after i thrash the car a bit. Swapped them over with brand new oem replacements and drove off only to have it 100x worse then before.. Fiddled around with it to get it to work proper and nothing.
Went to drive home and troubleshoot some more only to break down 2mins from my house Car just felt like it lost all power and i had no throttle at all. Pulled over and checked everything but the car wouldnt run. So i went and go the old sensors and put them back on hoping it would go back to normal. it did not. So towed it back to the workshop to see what the hell went wrong.. Sigh.
In other news splitter is complete. Will be putting it on as soon as i figure out what my pos car is doing.
instagramming this sh*t up
Re: charlie's na6
Fuel pump?
Have you got a fuel pressure gauge to check fuel pressure? My brother's car was good for about 20mins of driving then it would gradually break down and get worse until car wouldn't move...
Re: charlie's na6
Update:
Funny story .. So went to check to see what the fuel pump was like and looked in the tank to see it bone dry lol... UGHH feelin pretty stupid right night. Wish i bothered setting up the low fuel light lol So problem has gone away for now
So the splitter is done now. Happy with the finish and strength. Few things ill do next time when this one breaks
Re: charlie's na6
charlie_91 wrote:Update:
Your not the first or the last. At least it was a simple fix.
I chased a fault in my rx7, it kept on cutting power. To it was noted, that it was speed limited to 180km.
Got to love jap imports.
- Dweezle
Re: charlie's na6
Hahahahaha!!!!!!!
Glad it was an easy fix
That sort of thing is frustrating and relieving all at once.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
Re: charlie's na6
Would have been a good time to fill up with e85
- plohl
Re: charlie's na6
Splitter looks good man.
i was speaking to a guy with a radical at qr one day and he said it had been plagued with fuel issues - he finally decide to check the fuel tank and it was empty. Turns out the tube going to the tank is only like 1/2" ID or something, so if you try and fill it up at a servo, the it'll just keep clicking off as it's "full" haha.
plohl
plohl
Users browsing this forum: No registered users and 57 guests
