NC Fire extinguisher Bracket
Re: NC Fire extinguisher Bracket
Postby Regie » Mon Sep 17, 2012 3:25 pm
Here is the bracket i made for my car.
just a steel bar at the moment, im going to make some up out of thinner/lighter alloy. Im still using the standard mount bolts, there seems to be enough thread to secure the mount/seat
the seat can move forward a bit as you can see in the 3rd picture.
Ill make up half a dozen or so next weekend if anyone is keen
deanb90
Postby deanb90 » Mon Sep 17, 2012 4:09 pm
Keen!! but pref black :)
Postby Regie » Mon Sep 17, 2012 8:31 pm
deanb90 wrote:Keen!! but pref black :)
DIY paint...ill supply raw alloy :)
Dan
Postby Dan » Mon Sep 17, 2012 9:06 pm
LuckyCat wrote:Dan please ask him ! There should be a few forumites here interested perhaps?
I am still working on my own but my tool skills are limited.
Will do, Regies one looks pretty good but it wouldn't fit if you have a bucket seat that pretty much sits on the floor, I think a design like this would work, not sure if you'd need something extra to secure it to the floor though.
Postby Regie » Tue Sep 18, 2012 9:38 am
Something like my nb one I made up?
deanb90
Postby deanb90 » Tue Sep 18, 2012 1:30 pm
Im sold Regie, how much do you want including postage to 3121 Australia?
dude04
Postby dude04 » Wed Sep 19, 2012 5:05 pm
Regie may I please put my hand up for one if you do end up making a batch.
thank you.
Sailor
Postby Sailor » Wed Sep 19, 2012 5:25 pm
Regie, looks like the seat will move forward over the extinguisher with the green one?
Much better than mine which sits further forward.
Rob
LuckyCat
Postby LuckyCat » Wed Sep 19, 2012 6:39 pm
Here is the beginning of the bracket. Base is what Regie has done, I will use additional angles to extend outwards.
chris
Postby Regie » Wed Sep 19, 2012 8:18 pm
Sailor wrote:Regie, looks like the seat will move forward over the extinguisher with the green one?
Rob, it probably will if i drilled the holes for the beacket centrally :) the extinguisher sits off to the side a bit
Postby Regie » Wed Sep 19, 2012 8:20 pm
Saying that
The guys keen for a bracket, would you like it to be like the green one i have made... of have the extinguisher sit more on the floor like the one i made for my nb.
dude04
Postby dude04 » Fri Sep 21, 2012 7:46 am
Regie wrote:Saying that
whatever you think is best.. you have the experience. unless the green style bracket gets in the way I don't see the point of making it anymore complex? my passenger seat never moves forward.
LuckyCat
Postby LuckyCat » Sun Sep 23, 2012 9:01 am
Here is where I have got so far.
Using steel bar as a base 2x angle brackets extend outwards and attach to 2 x 90 degree angle brackets.
Then positioning the asssembly to allow some seat travel but most importantly so I can reach the damn thing. I'm not as limber as some of you others so I did the acid test
- extinguisher is in easy reach.
Postby Regie » Sun Sep 23, 2012 4:38 pm
Looks good Chris
I still hqvent managed to make brackets yet. In the next 2 days ill have something
deanb90
Postby deanb90 » Mon Sep 24, 2012 12:13 am
green ones fine, my passenger seat never moves
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 105 guests
