sailaholic wrote:Unless it was the blue v8?
nanotech wrote:Nah someone else bought that
Still on Carpoint/ Carsales - now $34.5k:
http://www.carpoint.com.au/all-cars/pri ... &silo=1011
1red5 wrote:huh? Maybe the ad was just never taken down as I thought mhj bought it.
chino wrote: I opted for some ssr professors 15x8 +4, as i want to run something aggressive, but now it seems it is too small and my bonnet cant open now as its too low and it wont budge. I need to run atleast 17/18" but there is no chance of finding a low offset rim at that size with the current lugs of the na6.
Sean wrote:While the kit isn't exactly to my taste, the workmanship and paint look to be top notch - nice job!
Hjt wrote:Still having front bar issues? I had stretched tyres over the rims, in sure a larger tyre such as a 225 with a beefy sidewall would help.
aka_juffa wrote:Chino,
If you are wanting to provide more clearance to allow the bonnet to open then I can only think of 3 ways to achieve this;
1. Raise the overall height of the car, i.e raise the suspension with adjustable coilovers.
2. See if you can install different hinges that reduces the amout of clearance you need to open the bonnet.
3. Go for wider tyres while retaining the height ratio. An example is a 205/50/15 tyre/wheel combo will give a total wheel/tyre height of 587mm, and a 225/50/15 combo gives a total height of 607mm, an extra 20mm.
Use this calculator to give you an idea of what is possible.
http://www.rimsntires.com/specs.jsp
J.
