ASI Radiator
mrpham
Re: ASI Radiator
Postby mrpham » Sun Aug 19, 2012 8:35 pm
I've also have an ASI, and used ASI in my previous cars. Never had any issues.
Current Forum Specials!
Purfler
Re: ASI Radiator
Postby Purfler » Fri Sep 14, 2012 5:33 pm
I just fitted a 42mm ASI to my '93 NA, the original radiator finally gave up the ghost. The ASI is not too bad a fit (for $155 deivered in a few days I'm not going to argue), the tabs for the upper retaining bolts didn't line up with the tapped holes but I think little judicious bending might cure that. One thingsI didn't allow for was that the ASI has a bigger capacity so I need to drain some of the diluted coolant and replace it with concentrate to get the 50/50 recommended.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
El Jay
Re: ASI Radiator
Postby El Jay » Sat Sep 15, 2012 8:08 pm
Yes I found that the tabs didn't sit exactly right but they were no real issue to tighten. There was more problem with the fan mounting points; I couldnt get the passenger side to sit properly! I've fixed it in a dodgy "she'll be right mate" way though.
I stopped filling the tank at 6 liters as that seemed to be almost full, but I ran a 33/66 blend.
Purfler
Re: ASI Radiator
Postby Purfler » Thu Sep 20, 2012 5:27 pm
El Jay wrote:Yes I found that the tabs didn't sit exactly right but they were no real issue to tighten. There was more problem with the fan mounting points; I couldnt get the passenger side to sit properly! I've fixed it in a dodgy "she'll be right mate" way though.
Loosening the mounting bracket on one side of the new radiator, lining up the mounting hole and fitting the bolt and retightening the bracket to the radiator fixed it perfectly.
I meant to say I bought genuine hoses (top and two lower), they cost almost as much as the radiator :D
Tim
superfluous2
Re: ASI Radiator
Postby superfluous2 » Mon Dec 10, 2012 11:27 am
I'm thinking of buying an ASI radiator for my NB8A this week, as the top tank is quite brown and I don't really want to risk it on the track..
Did anyone verify whether the 42mm eBay ones will fit, or should I go for the 52mm one?
The track day is this weekend, so I might have to go with the brown tank and do lots of cool laps if I can't get a clear picture of which one I need.
Any help would be great, guys :)
NB8A - Winton [1:49.2] Wakefield [1:16.8]
El Jay
Re: ASI Radiator
Postby El Jay » Mon Dec 10, 2012 12:50 pm
Yep I got a 42mm one that fitted my NB. Trick is though they don't list the one you need on ebay - get into contact with ASI and they should be able to supply you one however (they did for me).
Red Dragon
Re: ASI Radiator
Postby Red Dragon » Mon Dec 10, 2012 1:35 pm
And if your in a real hurry you can pick up in Laverton / Hopperscrossing area
superfluous2
Re: ASI Radiator
Postby superfluous2 » Mon Dec 10, 2012 4:36 pm
Been in contact with them and they seem to insist that the 52mm one listed for sale on eBay is for an NB..
Should I just buy one of the 42mm ones (listed as being for an NA)?
Pretty confused right now :P
El Jay
Re: ASI Radiator
Postby El Jay » Mon Dec 10, 2012 5:46 pm
There is this 52mm one, if that's what they're talking about.
The 42mm ones listed for an NA WON'T be compatible with an NB. All I did was ask for one to fit a 98-05 model and they were happy to send one along.
I personally wouldn't get a 52mm one. It's pretty large so it would impede airflow a bit; it's just an unecessary size.
PaulF
Re: ASI Radiator
Postby PaulF » Mon Dec 10, 2012 6:18 pm
52mm is massive overkill even for fairly modified or hard dríven cars. Plus it gives you less space for intake piping etc.
Re: ASI Radiator
Postby NitroDann » Mon Dec 10, 2012 6:43 pm
I run 52mm with front ducting and no undertray or fans. It works very well.
Its good for me because this allows me to pull the car apart very very quickly.
superfluous2
Re: ASI Radiator
Postby superfluous2 » Mon Dec 10, 2012 7:56 pm
Thanks for the info guys, I've sent the seller another message to ask if they do NB ones in 42mm.
If they don't, I guess I'll have to get the 52mm and try to fit it in there.
Cheers!
wazman
Re: ASI Radiator
Postby wazman » Sat Dec 29, 2012 10:53 pm
I've had an ASI 52 mm in mine for 2 years. Fits no problem. Cools my turbo setup no probs.
I recommend ASI , the Nissan silvia guys have been using them for years no probs too.
ilovedrift.com
wazman
Re: ASI Radiator
Postby wazman » Sat Dec 29, 2012 10:54 pm
ilovedrift.com
elitee
Re: ASI Radiator
Postby elitee » Sun Dec 30, 2012 8:32 pm
Also running an asi for about 1 year no issue at all
