Installation of mx5 mania cold air intake
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
JRBasia
Re: Installation of mx5 mania cold air intake
Postby JRBasia » Fri Sep 14, 2012 5:42 pm
This thread will help immensely when I get my hands on one too. Cheers everyone :)
Josh2232
Postby Josh2232 » Fri Sep 14, 2012 6:43 pm
hks_kansei wrote:
slug_dub wrote:A worthy addition is some foam tape around the end of the intake where it sits in the firewall, to reduce the vibration a little bit from WOT fun. :)
I used some U section rubber from Clark Rubber.
Does the same things, but looks neater and doesn't hold water (so it doesn't look manky after a while)
thats an awesome idea, im getting tired of the vibrations. i will definitely get some of that!
heres a photo of mine:
2006 Marble White NC. Soon to come, gold RPF1's
robmx5
Postby robmx5 » Fri Sep 14, 2012 8:18 pm
That's awesome, man. Can't wait to see how it sounds. I've got a cat back exhaust which sounds great already.
Josh2232
Re: RE: Installation of mx5 mania cold air intake
Postby Josh2232 » Fri Sep 14, 2012 9:00 pm
You will probably find that under WOT the intake is louder than your exhaust lol
Sent from my Lumia 800
robmx5
Postby robmx5 » Fri Sep 14, 2012 9:18 pm
Josh2232 wrote:You will probably find that under WOT the intake is louder than your exhaust lol
What does WOT mean?
Postby NitroDann » Fri Sep 14, 2012 9:26 pm
Wide Open Throttle.
bootz
Postby bootz » Fri Sep 14, 2012 9:33 pm
NitroDann wrote:Wide Open Throttle.
Dann's normal mode of driving. :mrgreen:
robmx5
Postby robmx5 » Fri Sep 14, 2012 9:45 pm
NICE!!
JRBasia
Postby JRBasia » Fri Sep 14, 2012 10:36 pm
WOT? He says. Can't hear you! Lol
Tallorder
Postby Tallorder » Fri Sep 21, 2012 5:42 pm
Er guys, how does such a mod affect roadworthiness? I would suspect cutting any type of hole of this size in the firewall would require an engineers certificate at a later date. I know this is a common and popular mod, but how do you stand when it's time to sell the car?
Postby hks_kansei » Fri Sep 21, 2012 5:55 pm
There's a few schools of thought.
One is that it's not actually the firewall being cut, but the thin sheetmetal just above where it ends. (I'm not sure how vicroads views this part)
The other is that if you need to sell the car you simply put something over the hole, bolt the washer bottle back and it covers the hole well enough that nobody notices.
Postby 93_Clubman » Sat Sep 22, 2012 2:08 am
hks_kansei wrote:One is that it's not actually the firewall being cut, but the thin sheetmetal just above where it ends.
+1 - access is into windscreen cowl area & the firewall (if you want to call it that) continues on the far side of the cowl area.
hks_kansei wrote:The other is that if you need to sell the car you simply put something over the hole, bolt the washer bottle back and it covers the hole well enough that nobody notices.
Or take it to a panel shop & get it repaired when it comes time to sell.
Postby Lokiel » Sat Sep 22, 2012 9:33 am
Might want to remove/customise that plastic shield sitting behind the firewall that sits above your intake, it will block off some of that cool air you're trying to breathe in.
Pamex
Postby Pamex » Sat Sep 22, 2012 9:44 am
To delete that hole, I'd put a thin metal plate either side. Pop rivet them on.
Nice and neat finish and only a few minutes of work.
ralt
Postby ralt » Wed Sep 26, 2012 5:30 pm
Hi.
DO NOT modify or remove the plastic panel above the air intake. It is there to prevent water from entering the cold air intake for the cabin. It does not in any way restrict the air intake on the system you are installing.
Return to “MX5 Technical Guides”
