Fitting LHD OEM criuse control to a RHD 90 NA
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
Re: Fitting LHD OEM criuse control to a RHD 90 NA
Postby Hammer » Mon Sep 03, 2012 7:08 pm
Great stuff. :mrgreen:
Tedsmx5
Vehicle: NA8 - Supercharged
Postby Tedsmx5 » Tue Sep 04, 2012 12:37 am
"Since I could not find a steering column stalk with the resume/accel-set/coast switch in it, I used a small toggle switch with a spring return (on-off-on) to centre and mounted it in a spare switch location next to the dash light dimmer".
You can get them from the US but the lights and wiper controls are reversed left to right.
Ted
ps. Very well done, I'm going to use a VN cruise control as they are small all in one and use a stepping motor, you run short of under hood real estate when you use forced induction.
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
zossy1
Postby zossy1 » Tue Sep 04, 2012 2:30 pm
Epic post! This is genuinely useful info, though I have to say cruise control is well down on my list of priorities :)
Return to “MX5 Technical Guides”
