Smokinscotty
Postby Smokinscotty » Wed Aug 29, 2012 11:47 pm
Disconnect the headlight rods and cable tie the headlight frame to the radiator support! 8)
So lets go!
BOYRCR
Postby BOYRCR » Thu Aug 30, 2012 12:49 am
Cracked the diff housing and drained the diff oil whilst at the drags tonight.........
If it aint on the rev limiter then you shouldn't be behind the wheel!
xhonda_boy
Postby xhonda_boy » Sat Sep 01, 2012 3:51 pm
93_Clubman wrote:
xhonda_boy wrote:Car wouldn't start yesterday afternoon when I went to crank it. Just keeps clicking over.
SO I left the car at work and came back today.
Pull out the fuel pump and gave it a good shake and now it starts.
** New fuel pump is on the cards **
Hey John, had the same problem last year - if you haven't already, while you're at check the fuel pump in-tank wiring harness for 'black wire': viewtopic.php?f=55&t=46425
Thanks Paul, I managed to fix my car with your method!
It was the intank wiring harnes as it was starting to discolor.
Cheers :beer:
Postby 93_Clubman » Sat Sep 01, 2012 5:15 pm
Cheers :beer:
Great to hear John - hopefully saved you some time. The plastic electrical insulator around the top of the fuel pump wiring harness on the one in my thread had deteriorated so badly that the positive & negative electrical connectors inside were almost touching. However, the black coating on the metal post & the metal connector had built up to the point where it became insulated, although it was intermittent about a month or so prior to that.
Smokinscotty
Postby Smokinscotty » Sat Sep 01, 2012 7:59 pm
Bolted in my Torsen and tailshaft! Tomorrow, murder the backing plates to clear the rotors, throw some oil at it and test! Yeeee haaaa!
So lets go!
evil_weevil
Postby evil_weevil » Sun Sep 02, 2012 9:17 am
Fitted front rda slotted rotors, front and rear QFM A1rm pads and brake fluid flush.
Pics of my old pads in my build thread...
And had beer while doing it.
Now getting car ready for next race meet.
viewtopic.php?f=73&t=62834
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Sep 02, 2012 9:36 am
Chopped one in half...
taminga16
Postby taminga16 » Sun Sep 02, 2012 9:46 am
I am about to give mine a quick clean and then it's off to Bendigo (35mins) to fill the other seat with a beautiful girl followed by a spirited drive to somewhere a hundred klms away for lunch :) , all under clear spring skies.
Best.
Greg.
Guy_Coles
Postby Guy_Coles » Sun Sep 02, 2012 4:58 pm
Black plastidipped my front and rear badges
looks way cool - thanks Adam !
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
TAS1981
Postby TAS1981 » Mon Sep 03, 2012 10:10 am
Started my custom ash tray ipod dock
Touched in a million stone chips on the front bumper
Took it for a long drive with the roof down in the beautiful weather to see my mate jump out of a plane!
WANTED Front lip for an NB8A - OEM Ideally, not a GV. NOW SORTED!
Tom - Grace Green NB8A 2000
91 Malibu
Postby 91 Malibu » Mon Sep 03, 2012 6:39 pm
Bought a hardtop see my garage thread for the story.
Cortina MK11 GTL
Mazda 3 SP23 Daily drive
El Jay
Postby El Jay » Sat Sep 15, 2012 7:43 pm
Finally got around to installing my new radiator, then took it for a test drive. It's been about a week since I've dríven it and in the meantime I have been driving an old Holden Rodeo. Boy is there a difference in the driving dynamics between the two :D
Mr Sexy
Postby Mr Sexy » Sun Sep 16, 2012 11:08 am
El Jay wrote:Finally got around to installing my new radiator, then took it for a test drive. It's been about a week since I've dríven it and in the meantime I have been driving an old Holden Rodeo. Boy is there a difference in the driving dynamics between the two :D
I know what you mean by that, driving a Kia pregio van all week and then hoping into the mx5 is mind blowing! :lol:
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sun Sep 16, 2012 4:21 pm
Respray.
8)
CHRISTolo
Postby CHRISTolo » Sun Sep 16, 2012 8:49 pm
Got the gearbox out to change the clutch. Not as hard as I thought, extension bars and flexi joints required.
Heaps of oil inside. Replacing all seals.
Will see how hard to put back tomorrow.
http://www.flickr.com/x/t/0098009/photos/75367607@N06/7991214141/
http://www.flickr.com/x/t/0094009/photos/75367607@N06/7991215669/
