Fuel injector clean.
mx5lover
Postby mx5lover » Sat Aug 25, 2012 7:07 pm
Hi all,
One of my fuel injector has vacumm leak again. :frown:
They are a bit old(23 years) and may not flow well,and also my 5 has really high fuel
consumption recently, I think it is time to do a ultrasonic cleaning and flow test.
Is there any a recommend place in Sydney( prefer west sub ). Any idea how much will be going
to cost?
Car: NA6
THANKS
Re: Fuel injector clean.
Postby Regie » Sat Aug 25, 2012 8:38 pm
nearly any service place should be able to do it
last time i had injectors cleaned (years ago) it was around the $20 per injector, cleaned, tested and new seals
mx5lover
Postby mx5lover » Sat Aug 25, 2012 9:36 pm
Regie wrote:nearly any service place should be able to do it
Do you take the injectors to the shop or just let mechanic do the whole job.
project.r.racing
Postby project.r.racing » Sun Aug 26, 2012 8:38 am
either. one will cost you alot more though.
last time i got injectors cleaned, i just asked around my local area and got the phone number of a cleaner mob. then took my injector to them. $100 including new seals and filters.
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Sun Aug 26, 2012 12:50 pm
Go and see Mick at wenty spares and performance, he has an mx5 turbo himself and does injector cleaning/servicing, doesn't charge much either.
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
mx5lover
Postby mx5lover » Sun Aug 26, 2012 7:33 pm
I'll try wenty part & performance next week.
Just one more question, when I take the injector out,
what do I use to block the holes to prevent dust go into the engine.
Thanks
