Emily's 04 VR SE
Re: Emily's NA6 V-Special Roadster
My car is dríven hard at a semi-functional height, I'd recommend not going for the trap lip because if it does hit something, you're stuffed. IMHO garage vary is best.
I like my girls how I like my cars, topless.
It's just showing respect Dann. Nothing personal. If you want to chat that's fine, but the theses about Emily's car.
Complete Exhaust Upgrade
FINALLY I have done something actually decent haha.
4-2-1 Maxim Works Extractors straight from Japan, coated in high-temp black paint
Custom 2.25" midpipe with Magnaflow high-flow catalytic converter
RS*R Muffler, big thanks to Jesse Streeter who brought this in for me
I would like to say a huge thank you to NitroDann, who welded up the midepipe to match the headers and muffler. It fits perfectly and has made a massive difference to the response and acceleration of my little NA6
oem temp sensor housing welded into new cat:
stock cat vs. magaflow cat
model no. for those interested
neat welds:
RS*R muffler, nfi what is says?
midepipe in mid-fabrication and final:
Test fitting the headers to oem system to check if they sat in stock position.
Unfortunately they sit about 3/4" shorter, which is still fine, it just means I have to cut the passenger side seatbelt bolt slightly shorter because the midepipe is touching it. The bolt looks too shiny to be original, and sticks out past the captive plate by about 2", so should probly be shorter anyway lol.
high tensile nuts & bolts & washers used to clamp the mode-pipe to the muffler:
stock rubbish
beautiful Maxim Works headers
neat welds:
stock rubbish
Looks great emily and Dann
Would be cool to get a video clip so we can appreciate the exhaust noise.
Im not sure if its a good thing or a bad thing but its reallyyyyyyyyy quiet. Although maybe anything will seem quiet after the other RS*R
Absolutely ZERO drone, which I am very happy about, because I was certainly worried as it does have a 3.5" f*ck off tip haha.
So its chambered.
Good result.
Fair bit of extra grunt?
Good result.
Nah I dont think chambered, rolled a small bouncy ball straight through it, its just got a pretty big resonance box, its bigger than stock muffler haha.
Why yes, yes it does
NitroDann wrote:Fair bit of extra grunt?![]()
I reckon your hearing is out from that old Milo tin then lol.
Well thats even better, Pretty close to spot on perfect setup for a weekend warrior with some tasty supporting bits!
- KevGoat
Really enjoying your build Emily. Jealous of the quality on the exhaust.
Keep up the great work.
Kev.
Kev.
- Aussie Stig
- Stig
How to make an exhaust swap interesting. Illustrative photos as well.
Not a fan of the big tip, but each to her own.
More E, More!
More E, More!
See, I thought the tip looked huge too, when the muffler was sitting in my living room, but actually on the car, its sorta small
stock 2.25" vs RS*R 3.5"
looks pretty stock from the side
I love it!
I love it!
Car looks good, I'm more interested in Hong Kong atm!
- Aussie Stig
- Stig
emily_mxV wrote:See, I thought the tip looked huge too, when the muffler was sitting in my living room, but actually on the car, its sorta small![]()
Now those wheels while attractive are a bit too fancy for my taste.
I recently came across a great mod for your colour roadster. See where your top dash crash pad and top of door pads are tan? They can be swapped for black ones. What it does is tie the dash together and makes it look a lot sleeker. Only the top bits need change otherwise you lose the tan effect.
Aussie Stig wrote:Now those wheels while attractive are a bit too fancy for my taste.
I love my wheels. I really do, they look really good in real life, because they have 16 spokes they look quite vintage to match the car, and they are also a very dull silver so aren't crazy shiny. Also because of the low profile tyre, the sidewall doenst flex as much as the normal 50/55/60 mx5 sized profiles, so it has less body roll and handles quite sharply
Unfortunately they are replicas of these:
OZ RACING - SUPERTURISMO GT
Aussie Stig wrote: I recently came across a great mod for your colour roadster. See where your top dash crash pad and top of door pads are tan? They can be swapped for black ones. What it does is tie the dash together and makes it look a lot sleeker. Only the top bits need change otherwise you lose the tan effect.
Oh ma gawd are you crazy, I would never ever ever ever change any thing to do with my tan interior. It is so lovely and although not to everyones tastes, it is really special, and when people see it in real life they always comment on how nice it is. And anyway it flows perfectly because the top of the door cards match the tan crash pad.
- KevGoat
I'm in full agreement with you Emily, I love the Tan interiors.
I had similar 16" multispoke wheels - TSW if I recall correctly - on a Celica a few years ago & I loved the look. Used to get heaps of comments about how good they were. Only negative I found was cleaning them
