Data Loggers, who uses one???
Re: Data Loggers, who uses one???
Racechrono for Android has been working a charm for me the past 3 events!
- david_syd_au
Hjt wrote:Racechrono for Android has been working a charm for me the past 3 events!
Good to hear.
I tried RaceChrono for the first time last Sunday (29/7/12) at Wakefield, running it on a cheap 7" android tablet ($120), and using an old 1Hz bluetooth GPS. Other than operator errors, it worked well.
The 7" tablet made it easy to read the display at a glance, which is why I used that instead of a phone, and even with the 5ish year old bluetooth GPS, the best laptime reported from each run was within 0.1 of the official times.
Of course, gathering the data is only half the challenge. The next step is to analyse the information, and decide how to improve. This thread has given a few links that I will follow up.
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
- yertimer
anyone using aim solo?
does it need an external antenna?
How does it compare with performance box?
NA8 94 Clubman
- Guran
- Vehicle: ND - 1.5
yertimer wrote:anyone using aim solo?
Haven't heard of this unit before. Looks nice and much cheaper than Performance Box. But I'm not sure they'll get many sales with the sheer lack of specification details on the website. Doesn't even specify the GPS sampling frequency which is critical for a decent laptimer. Would be nice if you could play with the software before committing to buy.
Looks like both options have an internal GPS antenna. You would only need an external antenna if your windscreen is made from athermic glass. Athermic windscreens are used to cut down the amount of UV radiation transferred through the windscreen. Unfortunately they also dampen/reduce GPS signals coming through the windscreen, in which case you need an external GPS antenna. Similarly, windscreens that have the FM antenna built into them can cause poor GPS reception.
No idea. Seems to offer virtually identical capability. Would be nice to try the software first. If you're interested, I suggest you phone the seller.
- yertimer
Thanks Guran
Sampler is 10Hz
Will ring the local supplier and find out more.
Here is a bit more background
http://www.aimsports.com/products/solo/index.html
It sells here from $445 + delivery
From the blurb above it has predictive timing and seems to do a lot of what performance box does?
Sampler is 10Hz
NA8 94 Clubman
- cooper1896
Andrew Cooper
White Na8 Clubman
White Na8 Clubman
Due to the NA not having OBD-II I'm looking at Innovates' DL-32 for data logging.
- Guran
- Vehicle: ND - 1.5
yertimer wrote:Sampler is 10Hz
You did better than me finding that info in the website!
Ah, that website is much better! Plenty of reading for you in there. Looks like these units are popular with kart racers. Might be worth asking zossy1 if he's heard of them being used here.
- CPDJ
- Learner Driver
I use Trakaroo on my android. As well as displaying lap and split times it automatically logs the best time of each session to Facebook (you can do each lap) and syncs to a web site (e.g. http://www.mytrackmaster.com/#SessionPl ... W9uGNnVBgw)
I use a Qstarz 1000EX for logging the GPS data and the associated software for reviewing my perfomance.
I use Dashware for synching with video from my Go Pro for results such as these: http://www.youtube.com/watch?v=zS8M6Ftz ... =autoshare
Colin.
Colin.
- timk
Yes, very happy with it!
In the process of seeing if my ECU can spit out serial data with RPM & TPS values so I can log those too.
Users browsing this forum: No registered users and 271 guests
