Rubber seal loose at top of driver's door glass
- davekmoore
The rubber seal has fallen off the chrome rail on the soft top where it meets the top of the driver's door glass. Various attempts to just re-seat it on the rail have failed so it looks as if it needs some kind of adhesive. What kind?
- geofiz
Re: Rubber seal loose at top of driver's door glass
These can be a pain to re-install properly, but no adhesive is required. I use a small plastic spatula to gently prise the lip of the rubber seal into the recess in the chrome strips. It takes a bit to get right.
NB8A - mostly stock for now
- davekmoore
geofiz wrote:These can be a pain to re-install properly, but no adhesive is required. I use a small plastic spatula to gently prise the lip of the rubber seal into the recess in the chrome strips. It takes a bit to get right.
Thanks. I'll have a go. Any more of a definition of a small plastic spatula?
- geofiz
Probably more of a putty knife than a spatula. Bought a set of three from Bunnings a while ago. Great for removing trim / clips from inside the car without damaging the vinyl / plastic trim.
insofar as aids for many automotive jobs are concerned these are now legion. In "the day" so many items had to be made out of scrap. The last place I look is Bunnings-its not automotive oriented. Try all the auto shops SCA Autobarn Repco Bursons and then bearing suppliers and tool shops.
- davekmoore
This starts to look like something I could get badly enough wrong that I'll just take it to an expert.
- davekmoore
Well, I cheated by gently removing the whole seal so I could see how it fits on the rail. Then removed 2 screws from the back of the rail which released the whole of that part of the seal assembly. Now that I could see the shape of the channel, with a bit of a fiddle I was then able to push the long rubber part back into the chrome rail leaving only the front end to be persuaded into the gutter with a bit of thumbnail action. Refix the screws on the end plate and all done. Except I also took the opportunity to go round all of the rubbers with the same thumbnail action. They were getting near to coming off in several places so I might recommend a bit of thumbage as preventative maintenance every couple of years.
Users browsing this forum: No registered users and 84 guests
