Any Recommendations for Turbo on the SE manifold
alexpav
Postby alexpav » Tue Aug 07, 2012 8:35 pm
Hey all,
I'm finding it hard to figure out what turbo's are compatible with the SE manifold.
I can get my hand on a brand new garrett t25 ballbearing but haven't yet found out if they hve an option that bolts straight up.
Currently I have a Skyline (front housing)/200sx(rear housing) and ive got another T28Ballbearing. I do have an adapter so could use eithe of these but would rather use a brand newy if possible.
Any suggestions? Will Garrett have a turbo to suit?
WILDCARD BITCHESSSS
Re: Any Recommendations for Turbo on the SE manifold
Postby NitroDann » Tue Aug 07, 2012 8:52 pm
Nothing particularly common or modern which is why I made this beast.
This is exactly stock SE but tubular and fits T2x turbos, in this case a ball bearing T28.
The other option is welding a flange to the stock manifold, however you want to use a 25mm thick plate with the correct bolt pattern and 'port' it to transition the 2 port shapes.
Or send me 1200 dollars :mrgreen:
Im kidding.
It doesnt cost 1200..
alexpav
Postby alexpav » Tue Aug 07, 2012 8:57 pm
haha looks great, but I want a stock look with the heat shield!
Isn't welding to the cast a bad idea? Doesn't the heat weaken it and prepare it to crack in the future?
WILDCARD BITCHESSSS
Postby NitroDann » Tue Aug 07, 2012 9:09 pm
Highly experienced welders -not me- using the correct filler rods can successfully weld to cast materials.
I suggest a mild steel log manifold with a T2x or EFR flange.
You will be able to use the stock heat shield too.
alexpav
Postby alexpav » Tue Aug 07, 2012 9:19 pm
Any particular manifold you suggest?
Are there turbos that mount to this stock SE manifold?
WILDCARD BITCHESSSS
Postby NitroDann » Tue Aug 07, 2012 9:24 pm
There are turbos that fit.
Im no expert on those turbos at all, however a bigger version will spool even worse.
Im recieved a deposit for a BP log for T25 and V Band downpipe from a forum member just half an hour ago. If you are interested I can do both at once. PM me.
Now I regret my 1200 dollars joke.. :P
alexpav
Postby alexpav » Tue Aug 07, 2012 9:39 pm
PM'd
Anyone else have turbo options/suggestions?
WILDCARD BITCHESSSS
timk
Postby timk » Tue Aug 07, 2012 10:26 pm
Have you looked into the BNR turbos? A mate of mine has a TD05-16G compressor somehow mated to the SE exhaust housing and it goes like a cut snake!!
