Has anyone broken their NB front swaybar mounts?
bootz
Re: Has anyone broken their NB front swaybar mounts?
Postby bootz » Thu Mar 22, 2012 8:43 pm
Okibi wrote:NB with RB sways and Racing Beat Sway Bar Brace Kit here too.
Are you running the 1.25" hollow RB frt sway bar ?
I wouldn't mind one, so if anyone in WA wants one I'll split shipping.
Postby Okibi » Thu Mar 22, 2012 9:02 pm
Yes, tubular front and the adjustable rear. Makes the NB very taily.
timk
Postby timk » Tue Jul 31, 2012 5:49 pm
FM/AWR mounts are in the car now but talk about a PITA.
The NB lower radiator brackets had to be modified to clear these mounts:
After searching miata.net, it seems others have had this same problem. I wouldn't have thought it would be rocket surgery to make a mount that bolts straight up? :?
Dave from MX-5/Automotive Plus did the fabrication work and it looks quality, it's just a shame it had to be done in the first place.
davekmoore
Postby davekmoore » Wed Aug 01, 2012 2:33 am
It would help to understand the different thoughts in this thread if there was some consistency in the spelling and meaning of the words "brake" and "break".
deviant
Postby deviant » Wed Aug 01, 2012 12:43 pm
saboteur...Not worth buying then? I'm not sure what I am looking at in your picture to see the modifications you had to make.
I am about to chuck coilovers and semi-slicks at my NB so I guess I need to look at this sooner rather than later!
zossy1
Postby zossy1 » Wed Aug 01, 2012 12:59 pm
To throw this in to the mix, I have seen my fair share of MX5s that have been involved in front end collisions. Even a minor impact can bend the chassis rail enough to put a nasty lateral load/bend into these mounts at the exact point sab's mounts have broken.
I wouldn't mind betting that there are a lot of cars out there that have been repaired and the mounts straightened, leaving a weakness in the mount(s).
rascal
Postby rascal » Wed Aug 01, 2012 3:33 pm
saboteur wrote:FM/AWR mounts are in the car now but talk about a PITA.
I put a set of these mounts (got mine from Goodwin, but same thing) in my NB8A when I put in heavier sways, and didn't have to modify any radiator mounts?
Though I did have to remove the radiator to get enough working room to be able to grind off the welds on the old sway bar mounts..
timk
Postby timk » Wed Aug 01, 2012 3:36 pm
I think I received old stock; a few posts on miata.net suggest that AWR modified the design so this was no longer an issue on the NB.
Users browsing this forum: No registered users and 222 guests
