Quick engine question???
sorry, i know this is gonna sound silly, but ive searched and cant seem to find an easy answer??
Ive got a 1990 roadster with a new engine in it
how do i tell if its a 1.6 or 1.8 engine by looking at it?
ive searched and on pics they both look the same, is there an easy tell?
thanks
thanks
Re: Quick engine question???
sorry mines not written on cam cover
its got an aftermarket top on it??
London to a brick its related to the engine nbr. Check the number / designation and cross check with someone that knows- forum sponsors, Mazda etc. The same question can apply to most engines- the designation of type defines what it is.
Cam angle sensor on right for 1.6 the opposite on 1.8.
1.8 engine numbers begin with BP. 1.6 numbers begin with B6. Engine number is stamped on a horizontal flat section of the block sticking out from behind and below the rearmost pipe of the exhaust manifold.
easiest way to tell is the air flow meter.
- Dweezle
Haha.
Ok, what colour are the tops of the injectors.
Blue=1.6
Tab=1.8
crank angle sensor on
Right=1.6
Left=1.8
A na6 conversion usually retains all 1.6 electronics.
Blue=1.6
Tab=1.8
Right=1.6
Left=1.8
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
It's only on the right if your facing forward. Most people look backwards at an engine bay.
NA6 cas in the inlet side. NA8 on the exhaust side
- Dweezle
sailaholic wrote:It's only on the right if your facing forward. Most people look backwards at an engine bay.
ahhh correct.
My bad.
Sorry if I confused you.
Jeremy Clarkson
Jeremy Clarkson
1.6s are pretty 'rev happy'. More than 1.8s.
Hope this helps.
Hope this helps.
manga nails it.
- Vehicle: Non MX-5
if it's registered, then the rego sticker/paperwork will have it also.
doesn't the 1.8 have raised writing on the cam cover? as opposed to the 1.6 being imprinted.
1989 Eunos Roadster
Users browsing this forum: No registered users and 106 guests
