Quick engine question???
speeedy
Postby speeedy » Fri Jul 27, 2012 7:05 pm
sorry, i know this is gonna sound silly, but ive searched and cant seem to find an easy answer??
Ive got a 1990 roadster with a new engine in it
how do i tell if its a 1.6 or 1.8 engine by looking at it?
ive searched and on pics they both look the same, is there an easy tell?
thanks
speeedy
Re: Quick engine question???
Postby speeedy » Fri Jul 27, 2012 7:18 pm
sorry mines not written on cam cover
its got an aftermarket top on it??
Postby Mr Morlock » Fri Jul 27, 2012 7:58 pm
London to a brick its related to the engine nbr. Check the number / designation and cross check with someone that knows- forum sponsors, Mazda etc. The same question can apply to most engines- the designation of type defines what it is.
myredmx5
Postby myredmx5 » Fri Jul 27, 2012 8:07 pm
Cam angle sensor on right for 1.6 the opposite on 1.8.
Postby manga_blue » Fri Jul 27, 2012 10:25 pm
1.8 engine numbers begin with BP. 1.6 numbers begin with B6. Engine number is stamped on a horizontal flat section of the block sticking out from behind and below the rearmost pipe of the exhaust manifold.
vrmmmpshhh
Postby vrmmmpshhh » Fri Jul 27, 2012 11:15 pm
easiest way to tell is the air flow meter.
Dweezle
Postby Dweezle » Fri Jul 27, 2012 11:36 pm
Haha.
Ok, what colour are the tops of the injectors.
Blue=1.6
Tab=1.8
crank angle sensor on
Right=1.6
Left=1.8
A na6 conversion usually retains all 1.6 electronics.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
sailaholic
Postby sailaholic » Sat Jul 28, 2012 7:32 am
It's only on the right if your facing forward. Most people look backwards at an engine bay.
NA6 cas in the inlet side. NA8 on the exhaust side
Dweezle
Postby Dweezle » Sat Jul 28, 2012 9:11 am
sailaholic wrote:It's only on the right if your facing forward. Most people look backwards at an engine bay.
ahhh correct.
My bad.
Sorry if I confused you.
Jeremy Clarkson
Postby NitroDann » Sat Jul 28, 2012 9:35 am
1.6s are pretty 'rev happy'. More than 1.8s.
Hope this helps.
Postby Mr Morlock » Sat Jul 28, 2012 12:26 pm
manga nails it.
project.r.racing
Postby project.r.racing » Sat Jul 28, 2012 2:35 pm
if it's registered, then the rego sticker/paperwork will have it also.
speeedy
Postby speeedy » Mon Jul 30, 2012 6:34 pm
cool thanks for the help
its a 1.6
toddl1
Postby toddl1 » Tue Jul 31, 2012 1:24 am
doesn't the 1.8 have raised writing on the cam cover? as opposed to the 1.6 being imprinted.
1989 Eunos Roadster
Users browsing this forum: No registered users and 137 guests
