Engine noise help
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
Re: Engine noise help
Postby 93_Clubman » Fri Jul 27, 2012 10:54 am
Being an NA6 (or NA8) it could be HLA noise, but usually it disipates after a while & then returns.
Many forumites have had excellent results using Nulon Lifter Free. Sometimes an oil change or different oil grade can also help. Could also be something other than HLA noise, but not easy to diagnose remotely with limited info.
HLA noise: search.php?keywords=hla+noise&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Apu
Postby Apu » Fri Jul 27, 2012 11:15 am
OP says noise is present when engine is cold and hot.
Is it really a ticking noise, or a tapping noise?
Postby 93_Clubman » Fri Jul 27, 2012 11:44 am
Apu wrote:OP says noise is present when engine is cold and hot.
blk na6 wrote:...and it's also there while cold and warm...
I've heard HLA noise in NA6 or NA8 when cold, warm or hot. With a bit of continued drving it sometimes stops making the noise, to usually return another day.
Postby NitroDann » Fri Jul 27, 2012 12:06 pm
Sounds like the Hydraulic Lifter Assemblies.
Nothing to stress about.
Replace them rather than use chemicals and oils to try to mask them. They can be had for 120 odd for the set.
Postby 93_Clubman » Fri Jul 27, 2012 2:12 pm
In case you're tempted to go for the middle option of cleaning HLAs as per:
http://www.miata.net/garage/hla/cleaning.html
Don't bother, as it's time consuming & doesn't necessarily give the result hoped for:
viewtopic.php?f=29&t=41116&p=529002&hilit=hla+cleaning#p529002
Postby 93_Clubman » Fri Jul 27, 2012 2:28 pm
blk na6 wrote:I might give it a go now after I get my headlights flush, gave it a quick read looks simple
Don't waste you're time cleaning them - either replace them or go the chemically enhanced option!
Return to “MX5 Technical Guides”
