Cooler pipes with A/C and P/S??
alexpav
Postby alexpav » Thu Jul 26, 2012 6:19 pm
Hey all
Started working on cooler piping today....I know there are a few posts on this....but I couldnt find a post that clearly showed if you to install a cooler with a LOW mount SE manifold but leaving PS and AC in the car on my NA8...
Id like to keep both but there is not alot of room there at all on the hot side in amongst all the AC and PS bits.
Any suggestions?
WILDCARD BITCHESSSS
Re: Cooler pipes with A/C and P/S??
Postby NitroDann » Thu Jul 26, 2012 6:25 pm
Has to come back up and over and in front of the A/C from memory.
alexpav
Postby alexpav » Thu Jul 26, 2012 8:20 pm
That all seems easy enough, but the problem is getting the pipe through down the bottom...so cluttered.
WILDCARD BITCHESSSS
Postby NitroDann » Thu Jul 26, 2012 8:43 pm
You can fit a 2.25" pipe through there, 2" is easy.
vrmmmpshhh
Postby vrmmmpshhh » Thu Jul 26, 2012 8:57 pm
when i was doing mine there was absolutely no way i was getting piping down through that area so i actuslly went around to the otherside of the engine. and down. it made the piping quite long but it was the only way i could do it. when i removed my aircon there was plenty of space.
alexpav
Postby alexpav » Thu Jul 26, 2012 9:03 pm
exactly what i found vemmmpshh (lol) I dont think I could get a 2" in there without it being pressed hard againt PS and AC hoses/pipes and the rad hose... Maybe il just give the air con the ass...
WILDCARD BITCHESSSS
vrmmmpshhh
Postby vrmmmpshhh » Thu Jul 26, 2012 9:13 pm
i went from this
to this.
i had the cooler modified so both end tank pipes point directly back and then straight up. even with a low car i haven't had a problem.
