As for the old one, well here's the diagnosis:
Wondering where all the actual clutch went?
Guran wrote:Nice stuff Tim. Do you have much whine from the SC? When I had my Cooper S, I found it was pretty quiet at first - fixed that with a foam filter CAI to replace the stock airbox. The SC whine after that was fantastic!
Guran wrote:Do you have much whine from the SC? When I had my Cooper S, I found it was pretty quiet at first - fixed that with a foam filter CAI to replace the stock airbox. The SC whine after that was fantastic!
Sailor wrote:Did you get some brake pads?
I've got a set of new and a set of bedded EBC Yellows that I could probably get taken down to you.
Bedded ones should be OK after just a few laps to settle them to your discs.
New ones probably not a good idea because they'll need a real good bedding.
