Wideband recommendations
sabretooth
Re: Wideband recommendations
Postby sabretooth » Fri Jul 20, 2012 10:16 pm
saboteur wrote:You might need to get a bung welded in a bit further down, too. From memory the current location is right near the turbo outlet?
I think you're on the money here. And I can get the bung moved this weekend - bam!
Sean
Postby Sean » Sun Jul 22, 2012 9:04 pm
aka_juffa wrote:Hey Geoff,
I had an aussie made wideband setup in my last 5. Not the cheapest on the block, but I found their support and product quality to be great. I believe you can get a DIY kit.
http://www.wb02.com
J.
x2.
I've had one of theirs for what seems like ages, have run heaps of cars on it and move it from car to car with a tailpipe adapter and long loom.
Works well, has always been reliable and like almost every wideband system accepts a reasonably standard and easy to aquire and replace sensor.
wydra
Vehicle: NB8A - Turbo
Postby wydra » Wed Aug 08, 2012 2:41 pm
Hi guys,
Just to dig this up again, has anyone tried the Innovate MTX-L gauge units? $199 and the controller is in the gauge.
http://www.diyautotune.com/catalog/inno ... p-467.html
The other option is I'll just go the LT-01 route. $199 for controller/sensor only. $209 for controller/sensor/basic digital gauge. $249 for controller/sensor/analog gauge.
http://www.diyautotune.com/catalog/inno ... -p-41.html
http://www.diyautotune.com/catalog/inno ... p-153.html
http://www.diyautotune.com/catalog/inno ... p-328.html
I will be buying very shortly so thought id get your thoughts.
Dale
NB8A - GT2560R, DIYPNP MS2
zoom zoom boom
sailaholic
Postby sailaholic » Wed Aug 08, 2012 4:00 pm
Yup, got one, like it much better then the lc1 before it. Much easier to know what's happening with it.
wydra
Postby wydra » Wed Aug 08, 2012 4:30 pm
Thanks for that, being the cheaper option it might be ok.
As far as I can see it does everything the LT-01 does just with the controller built into the gauge.
zoom zoom boom
sailaholic
Postby sailaholic » Wed Aug 08, 2012 4:49 pm
Yup, does require a bigger whole in the firewall as you have a plug head rather than just cables to pass through
plohl
Postby plohl » Mon Nov 05, 2012 10:58 am
Just so everyone else knows.
The Bosch universal part number for the LSU4.2 is 0 258 007 057(old version) or 0 258 007 200(new version)
So far I have been quoted $262 and $299 from supercheap and repco respectively.
US price seems around the $80 or less. Some including shipping, some not.
edit:
from http://wbo2.com/lsu/sensors.htm thanks aka_juffa for linking this!
$97 for a 0 258 007 200
the website also has a great amount info on the sensors.
plohl
