Emily's 04 VR SE
Re: Emily's NA6 V-Special Roadster
Car looks great Emily!
Keep up the good work.
- Gladiator
GREAT WORK Emily
I've just finished reading this entire thread, and I must say I'm impressed. I guess youth + enthusiasm = great results. You should be very proud of your achievements.
Andrew
Andrew
- Kev05
Excellent build up Emily.
As Apu puts it, you certainly put a few guys to shame and I'm one of them.
Good work!
Good work!
shake and bake wrote:Car looks great Emily!
Gladiator wrote:GREAT WORK Emily
Andrew
Kev05 wrote:Excellent build up Emily.
Good work!
haha thanks guys
Throttle body cleaning
So I was still having trouble starting my car when it was cold, so the next step was to clean the throttle body and cold start valve.
Thanks to spikes who came over to help me
Had to make gaskets out of "Gasket Goo" its pretty cool stuff haha.
We cleaned the butterfly plate with "Nulon Throttle Body Cleaner"; it was really gunked up with carbon :/
I am pleased to report a noticeable improvement in starting the car, and it seems slightly more responsive now
Coolant Hoses
Finally did the last of the coolant hoses, the heater ones were so hard and brittle.
It was fiddly getting them off, and in the process broke the dipstick haha but s'all good got another one and it looks nice now.
Alternator
So my NEW alternator started to fail. AGAIN. It sounded much worse this time, grinding and rattling and horrible :/
I was able to pick up another one, korean aftermarket unit from a wrecker, it is 10amp higher rating (70 as opposed to 60 oem) But I was told this is ok. It was pretty quick changing it over haha as I knew what to do from last time
But just as I was tightening it up, the motherfcking bolt snapped
So I had to go get another one and it made the whole job take just as long as last time lol.
At least the noise has gone now.
BUT NO now the god damn A/C compressor is starting to make the same noise.
Not gonna lie I'm really over all the sounds this car makes that it shouldn't
Coolant Hoses
Alternator
put the exhaust back on...wont hear any othber noises...problem fixed. thats what I do. ha!
viewtopic.php?f=73&t=62834
Haha yeah I took the RS*R off today, It was just too loud lolz
Headunitless/mini amp install
Since spikes has helped me out a few times I thought it was time to repay the favour, So I helped him out with the install of a tiny amp that replaces the head unit. It has RCA in and 2 channel out at 50rms each.
His car had the biggest mess behind the tombstone lol, this is all the stuff we cut out / didn't use
Very simple:
Mazda oem harness cut and soldered onto a male ISO harness, so a normal head unit can be plugged in if need be, then female ISO harness cut and soldered into amp harness.
Donesies!
Sounds pretty decent actually. Next step is to mount it up in the dash/under steering column, and just have the input and volume knob accessible in the cubbyhole void.
I think I am helping Hjt next with a head unit install, and now my neighbour has asked me to "make it so i can have my iPhone music in the car"
Very simple:
Donesies!
Should probably also note that this amp costs $0.99 + $5 postage from eBay China haha
Front Lip options?
So I am majorly struggling to make a choice.
1. OEM lip
2. Garage Vary lip
3. 100mm Trap lip
opinions
1. OEM lip
2. Garage Vary lip
3. 100mm Trap lip
opinions
Personally I think the OEM lip would suit yours best.
The Garage Vary lip seems to only work when the car is quite low and has other somewhat aggressive parts.
The Trap personally only works when you've also got a similar styled boot lip and have a more retro look to the car.
- Dweezle
I love the TRAP lip but it really needs the guards and wide wheels to pull it off!
OEM lip is pretty trouble free in regards to speed humps etc while also adding a bit of edge to the profile of the car i believe anyway.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
Yes I don't love the GV, it doesn't go very well with the BRG paint colour.
But I do have plans to go lower. Not clubroadster low, just maybe a 1" drop. Not on coilovers, I want to keep it comfortable.
And I spend a lot of time looking a aggressive/wide wheels haha so when I eventually make a decision on which ones I want that will change the look alot.
I want a GV but why the hell does it look ugly on our BRGs!!
