charlie's na6
Suspense
Re: charlie's na6
Postby Suspense » Thu Jul 12, 2012 8:03 pm
itrungs wrote:Maybe you can trick the cops by putting something like GRANNY LOLOLOL ... jokes
I know a guy who (with a combo of letters and numbers) has GUILTY as his plates. Needless to say he's lost a LOT of points from his licence...
Re: charlie's na6
Postby Magpie » Sat Jul 14, 2012 7:04 pm
charlie_91 wrote:So to try and get something that will read out everything and have an analog tacho i found the STACK cluster. it will display speed, tacho, boost, oil pressure, oil temp, water temp, voltage and also has a lap timer built in.. The beauty with this cluster is that its all standalone so makes it easy to install :) Also being able to display 4 readings at once and with a button to flick through makes it a lot easier and safer for me to know whats going on.
How do you propose to do the normal warning lights (indicators, high beam, lights, alternator etc) when you install your dash? If you haven't solved this problem let me know as I'm considering the Racepak dash. Anyway I'm going to start discussing this with MX5 Plus and the possible solution, however it would be silly to do this as a seperate exercise considering your plans.
zero00
Re: charlie's na6
Postby zero00 » Sat Jul 14, 2012 8:26 pm
Charlie
Will you have it ready for Lakeside Monday 23rd?
Hope so! Looking forward to watching how you go :D
Roger D-SUNSHINE COAST
charlie_91
Re: charlie's na6
Postby charlie_91 » Sun Jul 15, 2012 1:12 pm
Hey mate. Yeah car will be all ready to go. Manifold and rear housing are just getting coated now :) so one I fit that, flip the tires, wing back on and it's ready to go :D
gslender
Re: charlie's na6
Postby gslender » Sun Jul 15, 2012 1:25 pm
charlie_91 wrote:Hey mate. Yeah car will be all ready to go. Manifold and rear housing are just getting coated now :) so one I fit that, flip the tires, wing back on and it's ready to go :D
Hey Charlie, have you done any back to back testing of the wing? Does it really make any difference to the rear end grip through corners? What speed do you need to be going for it to have any improved grip?
G
charlie_91
Re: charlie's na6
Postby charlie_91 » Sun Jul 15, 2012 9:48 pm
G
Hey mate, no testing was done on the wing but I can assure u it works. Driving it hard on the street the rear feels light and unstable at speeds. I was gonna do some testing first track day but I decided to just put it all together how I built it and try it from there.
U notice the grip saw for instance around turn 1 and 2 at QR and coming though thre back section at lakeside and under the bridge.
Ofcourse it will work better at higher speeds but that's usually a given. I dnt think I'd ever want to do a track day with out it now seeing tht I'm use to how it handles.
gslender
Re: charlie's na6
Postby gslender » Mon Jul 16, 2012 6:54 am
Was just wondering that if it had an effect, it would also cause tremendous drag, but with sh*t loads of power (aka F1 cars) then grip is the issue, not power. Do you think the always drag is worth the sometimes extra grip? Eg. You might be quicker round the track without it!
G
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Jul 16, 2012 8:30 am
gslender wrote:Was just wondering that if it had an effect, it would also cause tremendous drag, but with sh*t loads of power (aka F1 cars) then grip is the issue, not power. Do you think the always drag is worth the sometimes extra grip? Eg. You might be quicker round the track without it!
G
I'd so much rather have a stable car with the wing then a twitchy car without. It's here to stay. Even if it is causing drag that doesn't bother me. I have power and straight line speed to deal with that do I don't see it as a problem.
Times don't bother me around the track. As long as I have fun and can drive it home at the end of the day I'm happy. I'm no f1 driver trying to gain every second possible.
Hjt
Re: charlie's na6
Postby Hjt » Mon Jul 16, 2012 8:37 am
Solution: build your own drag reduction system (DRS)
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Jul 16, 2012 6:09 pm
yeah i should hey.. that would be the only logical answer :lol:
16bit
Vehicle: NB8A - Supercharged
Re: charlie's na6
Postby 16bit » Mon Jul 16, 2012 6:20 pm
charlie_91
Re: charlie's na6
Postby charlie_91 » Thu Jul 19, 2012 4:36 pm
Update:
Not much happening atm. Waiting on my parts to be ceramic coated. Will put them back on this weekend and get the car prepped for track on monday :) Back at lakeside again so should be good.
In other news, got bored the other day and wanted to see how a diffuser would look lol :P
zero00
Re: charlie's na6
Postby zero00 » Thu Jul 19, 2012 8:57 pm
charlie_91
That's a nice sketch mate, i'd say frame it and wall mount!
See you Monday, but I will wander down Sunday to Lakeside and have a look at the Sprints and how much rubber they lay down!!
charlie_91
Re: charlie's na6
Postby charlie_91 » Fri Jul 20, 2012 5:54 pm
Update :D
Finally got the parts back from being ceramic coated :) Now its the mad rush to get the car ready for monday :D :D
Some pics
Hotside parts looking fresh :D
Killswitch mounted and hooked up :)
So much to do :P
Chillin with its big bro :)
Re: charlie's na6
Postby Magpie » Fri Jul 20, 2012 5:58 pm
I assume that your car is parked at its second home (MX5 Plus).
Users browsing this forum: No registered users and 18 guests
