NitroDann's Long Awaited Garage Thread
gslender
Postby gslender » Mon Jul 09, 2012 5:40 pm
Hey Dann, did ya get that bung? Do you think it can be located in such a way to minimize heat soak? Maybe a small shield or deflector?
G
Re: NitroDann's Long Awaited Garage Thread
Postby NitroDann » Tue Jul 10, 2012 8:47 pm
So I finally have a day off tomorrow...
So...
how do you want me to do a shield gslender?
And deviant I hope to finish your exhaust tomorrow.
gslender
Postby gslender » Tue Jul 10, 2012 9:53 pm
NitroDann wrote:how do you want me to do a shield gslender?
Not really sure. :?
But hoping you'd come up with something - I appreciate there isn't many a good option to 1) be in the best location to ensure it gets idle airflow, and 2) be out of the way from incoming heat from the radiator - I do expect I might just have to accept it will be prone to some heat soak and a shield won't probably be that effective, but if anything comes to mind, just do it and I'll either cut it off if I don't like it, or make some minor adjustment etc if needed.
No big deal.
Thanks again and can't wait to see what you come up with ;-)
G
Postby NitroDann » Tue Jul 10, 2012 10:14 pm
how long is the sensor you have from the end of the thread to the end of the sensor?
As in how far past the threads does the sensor stick out?
deviant
Postby deviant » Tue Jul 10, 2012 10:42 pm
NitroDann wrote:So I finally have a day off tomorrow...
So...
Me to!! :D
Are you going to do it in the AM? It would likely end up on a truck in the evening.
Are you going to stick it all in a box?
Either way can you let me know the approx dimensions and weights so I can log in to my account and see a rough cost and figure out best method to move it.
Bloody pushy clients :P
gslender
Postby gslender » Tue Jul 10, 2012 10:42 pm
NitroDann wrote:how long is the sensor you have from the end of the thread to the end of the sensor?
About 1 inch!
G
Postby NitroDann » Tue Jul 10, 2012 10:51 pm
Perfect.
no worries.
im more concerned that the whole intake elbow will heat up.
Also, im doing BOTH 90* bends right?
or just the down part?
gslender
Postby gslender » Wed Jul 11, 2012 12:20 am
NitroDann wrote:Perfect.
no worries.
Just the one down 90-ish..!
With IAT bung and iac connector baby pipe.
G
RedMX
Postby RedMX » Wed Jul 11, 2012 6:03 pm
I found this video on header construction while i was messing around on youtube. It may be some use to you Dann.
gslender
Postby gslender » Thu Jul 12, 2012 9:00 am
Any update on progress... Would love to have this installed by the weekend, but would need to be posted today I guess ;(
Postby NitroDann » Thu Jul 12, 2012 9:05 am
Posting this morning.
You wont be disappointed I promise.
PM me your address again. The forum was down yesterday for an hour or so before 5 so I had finished it at like 330, had a shower, then couldnt get the address by 5 to post it.
Postby NitroDann » Thu Jul 12, 2012 9:07 am
Just found your work address in my email inbox, use that again?
Can you just PM me the postcode then?
gslender
Postby gslender » Thu Jul 12, 2012 9:30 am
Yes pls 4000
G
Postby NitroDann » Thu Jul 12, 2012 5:28 pm
Grant you will receive your intake tomorrow, be sure to post photos installed.
Postby NitroDann » Fri Jul 13, 2012 12:50 pm
Show up ?
Users browsing this forum: No registered users and 17 guests
