Just a heads up, I recently fitted a Whiteline Rear Sway Bar to my car and for other reasons didn't get a chance to get down to spinning wheels for a month or 2 to get an alignment. When Stu got it up on the hoist, he said "Obviously your rear bar is working" and showed me the shape of my endlinks:
They are supposed to be straight...
I don't know of anyone else that's had this problem and the other NC owners that I've spoken to haven't had the same experience but it might be worth a check a while after you fit a new rear bar. A set of adjustable end links fixed it in a flash
NC Rear Sway Bars
- Guy_Coles
NC Rear Sway Bars
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
- JBT
Re: NC Rear Sway Bars
Just checked mine. All OK after some 30,000km on Whiteline adjustables.
- Regie
- Vehicle: NC - V8
wow...you must thrash your car, like you did mine haha
im yet to upgrade sway bars, but will keep this in mind when i do...cheers!
- Guy_Coles
Regie wrote:wow...you must thrash your car, like you did mine haha
I'm never going to live that down am I... Not only can I bend end links but loosen sump plugs in a 10 minute ride
probably more of an indicator that I need to look at my driving style, smooth and progressive is faster and does less damage......
The endlinks were great and let me dial out any preload of which there was quite a lot as the originals were a bitch to get off (might have been as they were bent though), interestingly both were bent to different degrees and in 3 dimensions that didn't match:
- Regie
- Vehicle: NC - V8
Hahah.
I had the same problem with my nb. Installed white line adjustables, and the front end links looked like bananas within the first month and rattled like crazy.
There isn't much meat in the standard end links. Good to see you have it sorted. Looking forward to a battle on the track at the club track day
Users browsing this forum: No registered users and 194 guests
