go 9:1 or close.
there you go
Questions. 1.8 head gasket. pistons.
Re: Questions. 1.8 head gasket. pistons.
- alexpav
Woo ok measuring the bores on the block I got the order the pistons then the headaches woohoo thanks for the input all
WILDCARD BITCHESSSS
- jerrah
I found the T28 spools fairly quickly but only seems to make 5psi (unless I have a leak somewhere) on the stock actuator.
5psi is fine until I get my TPS issue sorted!
1991 MX5
- alexpav
Selling T28....t25 is enough need the money to spend on pistons haha
if i use 9:1 ish how will this go if i decide to take the turbo gear off and run it standard again??
What is compression ratio of standard na8?
WILDCARD BITCHESSSS
Nonononono!
The T28 isnt about more power.
Its ball bearing also. Its a better turbo in every way. Keep it. Better spool, better torque, better drivability, better everything.
- alexpav
haha i know i know but its worth more than the T25 to sell (and to replace if ever needed), ive spent wayyy more than i wanted and I havent even started doing any work yet! ( i should have just bought shadowruns complete kit!)
anyways...you can buy it if you want
9:1 pistons will be ok withuot the turbo bolted on?
WILDCARD BITCHESSSS
I think na8 was only 9.5 std. So will just be a bit slower
- bear2230
I was tossing up between these:
http://www.frsport.com/index.php?target ... t_id=26648
and
http://www.frsport.com/index.php?target ... t_id=26642
but ended up with what Daniel wanted to use. Arias 9:1. Mania liked supertech 8.6:1 though and when they quoted me for the rebuild that is what Dave recommended.
Richard
and
Richard
+1 supertechs, based on all advice from people who I know and trust.
- alexpav
Thank you all for advice!
So I think it is going to be either the supertechs or the CP pistons.
Supertechs if my new block measures to be 83.5mm and if it measures up at 83mm I will be going the CP's.
Again, thank you for all your advice, im sure I will be asking many more questions once I start the build!
SO many things to bold onto this car ahhh
I can't stop buying things! turbo related and other randoms bits completely unrelated!
Ah well, the next time i drive this car it will be a unique machine!!
WILDCARD BITCHESSSS
- alexpav
Im obviously not going to bold things on to the car, i will bolt them on though! hehehe
Thanks again guys!
Thanks again guys!
WILDCARD BITCHESSSS
Users browsing this forum: Google [Bot] and 136 guests
