HILLCLIMB, to SEMI or not to SEMI??
- Dweezle
With a Hillclimb event this Saturday, Just wondering what the consensus is for tyres?
My brother is doing his first Hillclimb and we have a set of used Semis on Wats in the garage but i am doubtfull of getting heat into them before the run.
Am i correct in thinking it would be better off just using street rubber?
IE- Adrenalines that are on the car already.
He will be taking the 5 there and i will be lugging gear and a passenger in a hatchback so i will have the room but if it is completely useless then What is the point?
Thanks in advance.
Thanks in advance.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Dweezle
Re: HILLCLIMB, to SEMI or not to SEMI??
Forgot to mention the track is Oakburn Park at Tamworth.
Temp is predicted to be about as low as 2 Degrees!! YIKES!!!!
Jeremy Clarkson
Jeremy Clarkson
- Old Dude
Put ice skates on it ...
MX 5 2001 Grace Green
NB8B
NB8B
- Dweezle
Haha. Yeah maybe save the space for bloody chains!!! Damn Winter!
Jeremy Clarkson
Jeremy Clarkson
if you have a super soft semi that will heat up right away, go for it, say an r888 on the soft compound.
otherwise a good street tyre might be best as some other semis wont even warm up to get the best out of them and maybe even slower!
viewtopic.php?f=73&t=62834
Below 15 degrees it takes me about 60 secs to warm up medium compound r-specs on a track, though they're probably better than street tyres after about 25-30 secs with weaving. It would need to be a reeeeally long hill climb to get them working at Tamworth.
- wozzah1975
Definately use semi's, even cold they will work better than an ordinary tyre.
cheers
Woz
cheers
Woz
- Dweezle
wozzah1975 wrote:Definately use semi's, even cold they will work better than an ordinary tyre.
cheers
Woz
Ohh really??
That goes against what I've been told. Thanks for the input.
Maybe they are worth lugging up there??
They are Yokohama M compounds.
Jeremy Clarkson
Jeremy Clarkson
- Jeo
Not all semi's are created equally of course, but the fastest guys at the Fairburn track here in Canberra are all on semi's. We're talking <50 second run times.
- Dweezle
Thanks Joe.
Have you seen any tricks they use to heat them?
Im guessing you can't exactly go for a quick blast round the block first :grin:
Jeremy Clarkson
Jeremy Clarkson
Here in Canberra people do a big burn-out onthe pad to get some heat into the rears (and feel out the grip levels). Not much for it on the fronts.
I think I agree with Jeo that, warm or not, the Semis are quicker in Canberra.
- Vehicle: NA6 - Turbo
I would put the semi's on and go for a drive for 20 minutes before the event
That way you will get a bit of warmth into them instead of being stone cold
Olboy
Olboy
- Smokinscotty
+1 for use the semis. I think a subtle burnout would be best, saw a few cars suffer from big under steer at turn 1 at Grafton after big burnouts.
Is this the state round? If so be sure to check out the Dallara with the motorbike V8 in the back!
So lets go!
- wozzah1975
Dweezle wrote:wozzah1975 wrote:Definately use semi's, even cold they will work better than an ordinary tyre.
cheers
Woz
Ohh really??
Drive up there on them
I run the Kumho's, the V700 victor racers in a medium, because thats the only compound they do in my size. They are a very soft meduim at 50 treadwear though.
On the tracks that allow you to do a "tyre warming exercise" I deliberatly set my car up to oversteer. When I warm the rear tyres the car is then usually about balanced during the hillclimb run. On some of the longer tracks on a warm day enough heat is generated in the front tyres toward the end of the run to make it oversteer again, but I have found overall this technique works pretty well, and it promotes generating heat into the front tyres during the run IMO.
The competitive guys in the hillclimb series down here are all on semi's.
Woz
- Jeo
Not sure about other events but here they specifically disallow people from going for a drive to get heat in them by making you line up for at least 5 minutes (normally more like 10) before your run. Most guys will position their car so that the tyres are out of the shade and facing the sun to attempt to keep some heat in them. While I'm not convinced it would make a noticeable difference, it is entertaining to watch.
Users browsing this forum: No registered users and 271 guests
