timk makes up for talent with an EFR
- timk
Re: saboteur's NB
Head has been torqued down now, plus water and oil pumps are on:
I decided to go with the BP6D oil pump (used on the VVT models and the SE) as it can flow more and is a bit beefier.
One other change I've made is swapping to a JDM tacho; it makes the redline area much easier to see with your peripheral vision on track days:
It is an easy swap to do however you will find the 0-2 area not as well lit as the rest of the gauge. The Australian cluster doesn't have anything in this area so there's no provisions for a bulb or light to get through. I don't find it to be a problem.
- zero00
Re: saboteur's NB
saboteur
Looking good Tim!! Will it be ready for 23 July? Also, are you adding a turbo?
Roger D-SUNSHINE COAST
- timk
Re: saboteur's NB
Thanks Roger.
The car itself may be ready for the 23rd but it is unlikely I will have it fully run in and tuned by then.
- jerrah
Re: saboteur's NB
Looks really shiny compared to my new motor! Hopefully see mine started this week. Turbo bolts = argh. Supercharger was heaps easier.
1991 MX5
- jerrah
Re: saboteur's NB
If your motor is still on the engine stand I think I saw it today. How long before it's in your car?saboteur wrote:
1991 MX5
- timk
Re: saboteur's NB
jerrah wrote:If your motor is still on the engine stand I think I saw it today. How long before it's in your car?
I have been told it will be ready by Monday, so we will look at booking in a time after that for the transplant. Getting pretty excited!
- timk
- zero00
Re: saboteur's NB
saboteur
Saw the assembled engine a few hours ago when I stopped in at Automotive Industries [MX5 Plus] looks great!! Love the cam cover, just like mine!! That really sets it off Tim - well done!
- timk
Re: saboteur's NB
Timing all done, front covers on and powdercoated cam cover on:
Starting to look pretty special!
Re: saboteur's NB
Awww, I reckon it should have been painted "louder", that way it would have looked faster!
- I've seen Roger's in the flesh and it does look good.
Re: saboteur's NB
I recon just buy back the black sc one! No reroute?
- timk
Re: saboteur's NB
sailaholic wrote:No reroute?
I'm using an SE head and SE head gasket, so the reroute isn't as critical:
http://forum.miata.net/vb/showthread.php?t=350182
I wanted to keep it looking fairly sedate.
- zero00
Re: saboteur's NB
Yeah it does look pretty smart and thanks for the compliment! Saw sab's on Saturday when I called in, looks just great, Jason was also saying every refresh/rebuild they do will have the same done, well worth the small cost involved
- TieNN89
- timk
Re: saboteur's NB
A bit more progress. Snail bolted to manifold and test fitted:
Waiting on some exhaust studs for the head.
Users browsing this forum: No registered users and 145 guests
