Andrew's '93 NA6 - KL V6 swap
16bit
Vehicle: NB8A - Supercharged
Re: Andrew's '93 NA6 - KL V6 swap
Postby 16bit » Fri Jun 15, 2012 10:26 am
i personally think the engine is rejecting your custom manifold because it wants a supercharger on top instead :mrgreen:
Jace
Postby Jace » Fri Jun 15, 2012 5:58 pm
it wants a throttle per cylinder!
Beelzeboss
Postby Beelzeboss » Fri Jun 15, 2012 7:30 pm
Gladiator wrote:Well I've just read this from start to finish. Totally AWE-INSPIRING!!!! Well done. BTW, what are you doing at uni? I'm guessing Engineering?
Andrew
Thanks Gladiator, yeah I'm doing mechanical engineering at uni.
16bit wrote:i personally think the engine is rejecting your custom manifold because it wants a supercharger on top instead :mrgreen:
Jace wrote:it wants a throttle per cylinder!
:lol: Both good ideas, though I'd lean toward the supercharger since I already have one and it might actually make this swap worth while, power wise anyway :lol:
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
16bit
Postby 16bit » Fri Jun 15, 2012 8:06 pm
i think you should appease the masses and do both!!!!
Beelzeboss
Postby Beelzeboss » Sat Jun 16, 2012 7:38 pm
16bit wrote:i think you should appease the masses and do both!!!!
:mrgreen:
It's a week until my last exam so I took this afternoon to do a bit more welding. The new gas is working well but now I have an issue with the foot pedal control which I haven't noticed before. The first 10% of pedal travel increases the amperage, the rest does nothing. It makes no difference at all whether you're at 20% or 100%. I'm going to take it back to the company I bought the welder from and have it repaired/replaced.
This is as far as I got with the new manifold
You can see here the difference between contaminated gas and pure argon.
Bad gas:
Good gas:
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Fri Jun 29, 2012 3:13 pm
OK I'm on holidays now so I can finish the car. I'm part way through making a washer tank to go in the boot as there's not a lot of room in the engine bay. I'll post pics of that tonight when it's finished (hopefully). After that all that's left is to crank up the welder and put the finishing touches on the intake manifold and do the intake piping, which is fairly straight forward.
The wheels I was given for my birthday arrived today! They're 13x8 +20 V2 Competition wheels, they fit over the 1.8 NB brakes :D
Andrew
NA-6 2.5 KL V6
myredmx5
Postby myredmx5 » Fri Jun 29, 2012 3:30 pm
HAPPY BIRTHDAY
username
Postby username » Fri Jun 29, 2012 3:48 pm
Happy birthday! I've loved those wheels for quite a while, pity there aren't many 13" tires. What do you plan to wrap them in?
"signatures - a good place for a list of your cars modifications" -Jace
16bit
Postby 16bit » Fri Jun 29, 2012 5:09 pm
225 45 13 888's or nothing.
jerrah
Postby jerrah » Fri Jun 29, 2012 5:11 pm
I love this thread. :beer:
1991 MX5
16bit
Postby 16bit » Fri Jun 29, 2012 5:15 pm
or possibly 205 60 888's
Postby bruce » Fri Jun 29, 2012 6:17 pm
Beelzeboss wrote:OK I'm on holidays now so I can finish the car. I'm part way through making a washer tank to go in the boot as there's not a lot of room in the engine bay.
Make an alloy Nopro washer bottle for the windscreen cowl. Like this one (not sure if link works). Looks rather simple;
http://www.ebay.co.uk/itm/Mazda-Mx5-Eun ... 3cc6003dd9
Beelzeboss
Postby Beelzeboss » Fri Jun 29, 2012 6:36 pm
Thanks guys :)
bruce wrote:Make an alloy Nopro washer bottle for the windscreen cowl. Like this one (not sure if link works). Looks rather simple;
That's a good idea but I've 90% finished my boot mounted washer bottle. I've put a new hose under the carpet and I'm going to use a wire which was part of a previous alarm install which runs to the boot.
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Fri Jul 06, 2012 12:24 am
New intake manifold just finished. It doesn't look like it flows well, the plenum is too small, the runners are too long and it looks like shite but it should at least work.
A couple of wire extensions and reassembling the front bodywork and I'm ready for tuning.
I've signed up for a semester of TIG welding classes at TAFE, 4 hours every thursday night. Hopefully that will improve my welding :D
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Sat Jul 07, 2012 1:16 am
I bought 20L of E85 on the way back from uni today, any tips on tuning? With any luck the car will move under it's own power for the first time in ~8 months in the next few days.
I've also booked my emissions test for the first available spot at Botany, 1st of August :(
Andrew
NA-6 2.5 KL V6
