NitroDann's Long Awaited Garage Thread
16bit
Vehicle: NB8A - Supercharged
Re: NitroDann's Long Awaited Garage Thread
Postby 16bit » Thu Jun 28, 2012 4:15 pm
living up to the deviant name. 8)
dimarg
Postby dimarg » Thu Jun 28, 2012 4:28 pm
forgive my ignorance, but where does the intake go to?
- Giuls
16bit
Postby 16bit » Thu Jun 28, 2012 4:41 pm
i don't tink its been changed from the intercooler piping just yet.
Postby NitroDann » Thu Jun 28, 2012 4:58 pm
Sorry if these are in any way confusing.
You can see 2 pipes marked 'cat' and 'hotdog' being used for fitup while I try to work out exacty where it will split to 2x2" pipes, the whole exhaust will be built with no components, then the components added, because I dont have a hoist its difficult to maneuver an exhaust with a cat a hotdog flanges that twist (v bands spin any way around) and 2 mufflers.
The photos suck, deal with it.
deviant
Postby deviant » Thu Jun 28, 2012 5:03 pm
Looking good Dann...I am certain that the brace is the same as my NB8B has. I really dont think Mazda changed a great deal of metal work between models.
Postby bruce » Thu Jun 28, 2012 5:44 pm
I thought you were fitting a stealth turbo down under the boot.
Postby NitroDann » Thu Jun 28, 2012 5:57 pm
Fabricated 2.25"-> 2x 2" collector.
This is to take it down to 2" and keep exhaust velocity out the twin tips.
deviant
Postby deviant » Thu Jun 28, 2012 8:20 pm
Ah yes I see how you shrunk it. Still looking awesome...really seems to be flying together.
bruce wrote:I thought you were fitting a stealth turbo down under the boot.
Would you even get enough exhaust velocity back there for it to work and would it make enough boost to get all the way back to the engine? Would be an interesting thing to see!
But no this is not a boot mounted turbo. I approached Dann a while back to build me an exhaust system and he has managed to tee it up with getting an NB for some other work so he is able to build my exhaust on that car at the same time. Good job he seems to enjoy it!!
Postby NitroDann » Sun Jul 01, 2012 5:15 pm
So..
IF JAMES COULD RETURN MY CALL I COULD CONTINUE HIS EXHAUST...
Until then, Im running off to get a camera and then Ill post some updates from there.
Postby Okibi » Sun Jul 01, 2012 5:53 pm
It's beautiful weather here in Perth, James is probably on the coast somewhere sipping cold beer and watching the world go by.
Postby NitroDann » Sun Jul 01, 2012 7:23 pm
So heres the updates..
Due to different interpretations on what exactly 2" and 2.25" actually is, there have been a fair few fabricated cones.
Basically a lot of parts are designed to be mig'd together as fast as possible. For this reason 2.25" catalytic convertors are not 2.25", they are 2.4 or something so that you can slip it over a 2.25" straight pipe or bend and just aim your MIG at it and spray that pipe like you are mowing down enemies with an AK47. :shock:
So Anyways, in order to get properly converging pipes and have no steps in the pipework Ive done a lot of extra fab.
It means extra work, extra TIG welds and extra flow velocity. So now theres so little pipe size difference that none of the pipes will fi into each other at all. Less than a millimetre.
You will see that the whole exhaust is completely above the frame rails and factory bracing.
Feedback?
deviant
Postby deviant » Sun Jul 01, 2012 7:38 pm
I cant pick anything wrong with it at all, very happy with what you have achieved so far!
I love that up until where it will split for the twin exit everything is fitting in with where the original exhaust runs, there will never been an issue with it being really obviously aftermarket or issues with ground clearence. Well done Dann.
deviant
Postby deviant » Mon Jul 02, 2012 10:51 pm
I entirely forgot to ask earlier...Did you figure out the infamous EGR thingy?
Postby NitroDann » Mon Jul 02, 2012 11:28 pm
havnt done it properly yet but looks easy enough, otherwise, well haha..
ive had a few drinks...
Basically with a welder and an angle grinder you can do anything. Its awesome, everyone should try it.
So all is good haha
deviant
Postby deviant » Mon Jul 02, 2012 11:42 pm
Dont blame you for having a few...You sounded knackered earlier!
