Ben Sale's white 1990 NA6
- -alex
Re: Ben Sale's white 1990 NA6
Mmmm wakie I remember my first ever lap. 1.23.2
- Pamex
That's a great time Alex. Congratulations.
- bensale
I was consistant at Wakefield too
Just about every lap
But I was pretty happy to get into the 15s 1st time there... Just had to push a bit to get there, just couldn't find grip! I would be interested to do regularity too as quite often I see similar things... But I guess I enjoying the pushing at 100% part too much... 3 of my laps at Nurburgring were within 1 second of each other... Which I thought was incredible over 22km's and especially as I was trying pretty hard!
I'm hoping soon mine will be doing less kms as I want a nice cushy modern daily instead of a temperamental Italian...
www.othersideproductions.com
- Pamex
Ah! I know that patch. One of the OzMazda guys convinced me I killed a duck when I came off there. It was the soaking wet day and there was a small lake formed right there. I did get a bunny on the way home a few days later at 3am just north of Benalla though. Luckily I managed to get all of the bunny out before the dyno day a few days later so we didn't smell like we had a bunny BBQ.
I know I just need to get the accelerator down more. Looking forward to going back and doing that very soon. My lines and gearing are spot on, it's just the right foot that needs some work and some aggression!
- -alex
Pamex wrote:That's a great time Alex. Congratulations.
A great time is a 1.05 a good time is a 1.15 a n00b time is 1.23
- -alex
Anyway I topic.
Car requires a new hand brake and will receive further thrashing.
- bensale
Has anyone changed a handbrake cable before? Where did you source the part from, quite expensive, will work out at around $200AU + from the UK for all 3 parts of the cable.. If thats what it costs okay.. Just seems like it should be less..
- Pamex
Try Allmaz. That's where I'll get mine. If I recall, there is a write up on miata.net.
- fattima
What I'm posting on the forum
Would a NB one fit? If they do you can have the one off the NB.
- bensale
- bensale
Looks like the front half of the cable is the same.. But the rear bit where it splits to each side is different apparently.. But going by the photos on MX-5 Parts website I can't any major differences... There are a lot of NA-NB parts that aren't meant to be interchangeable but I've found are, maybe this too..
The only difference I can think, is possibly length (although it would be minimal difference)
Didn't the NB (or NA8?) have a slightly wider track than the NA6 or something?
- bensale
Pretty sure thats all the same as all of the parts that would be affected by a changed like that are interchangeable. The NB has 5mm wider track due to the uprights/ wishbones but my NA's whole rear subframe could go in your NB and vice versa let alone just the uprights. Front is a little more complicated in the changes but still interchangeable.
The NC has a much wider track but NA /NB is the same shell, mount points etc. I figure if the front cable is the same then the rears should be the same length. Only change could be if they pressed the floor pan slightly differently and routed the cable longer or shorter.
- bensale
I got a new handbrake.. Massive thanks to Bruce!!! Turns out I only needed to replace the part that goes from the lever to the point where it splits to go to each calliper.
I then went and had some fun...
Thanks to Bob for filming the video and an extra huge special thanks to the Boaks for lending me a set of wheels and tyres to get to Adelaide the day after so I could shoot this video... The wheels and tyres they gave me and are on at the moment are a set of 17s with R-specs.. Anyone with a lowered / stiffer car I can advise you to never actually pay money to do this to your car bith for the sake of your back as well as the handling characteristics of the car!!
Also shot a few videos of interest recently... WTAC with 7tune and the Phillip Island 6 hour for Mazda Australia to help promote club level motor sport and the MX-5.
- Dweezle
Can you now lock the rears with the handbrake??
None of my mx5s have been able to do that
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
