Wheal bearing replacement
Timmeh
Postby Timmeh » Fri Jun 15, 2012 10:41 pm
I have noticed that when driving the rear right wheel has a very audible wobble noise.
It increases and my speed increase and vice versa.
I believe it may be the wheal bearing.
How do I go about sourcing one, cost, and fitting it.
Are mx5s bearings sealed?
any info is much appreciated
Norwell: 1:14.3
aka_juffa
Re: Wheal bearing replacement
Postby aka_juffa » Fri Jun 15, 2012 11:06 pm
Where are you located. This will help us point you at a local resource, such as one the forum sponsors, such as MX5Mania in Sydney, or MX5 Centre in Melb.
If you don't buying shopping on the net try
http://www.mx5parts.co.uk/
I believe a number of forum members have good experiences shopping with them.
Here is a specific link to their rear wheel bearings. http://www.mx5parts.co.uk/rear-wheel-be ... rrency=USD
J.
ps I don't honestly remember coming across too many questions regarding wheel bearings on this forum. Also of the 3 MX-5s that I have owned I never had the need to replace the wheel bearings. Not saying that you are not correct in your thinking, just might be unusual is all. Have you checked your rear brakes to see if they have seized...search on here for 'slider pins' and you will get the picture.
Timmeh
Postby Timmeh » Fri Jun 15, 2012 11:15 pm
located in Brisbane.
I will have a look tomorrow morning to see if the brakes making contact.
its very audible and happens regardless of gear/neutral/under breaking which leads me to believe its a bearing not the diff or something else.
Norwell: 1:14.3
yuge
Postby yuge » Sat Jun 16, 2012 12:29 am
i just got a pair of front and rear bearings from CBC (http://www.conbear.com/)
Fronts were $125 each (NTN Bearings made in Japan)
Rears were $80 each (Koyo made in Japan)
Timmeh
Postby Timmeh » Sat Jun 16, 2012 6:53 pm
are the bearings sealed ?
Norwell: 1:14.3
evil_weevil
Postby evil_weevil » Sat Jun 16, 2012 8:01 pm
sorry to hijack thread....but I think its about time I replaced mine too.
I found this online
http://www.miata.net/garage/fronthub/index.html
although this is for the front (above link), anyone had any expeience?
viewtopic.php?f=73&t=62834
Timmeh
Postby Timmeh » Sat Jun 16, 2012 9:15 pm
awesome tutorial that.
Has anyone done this before to the rear?
is the process the same?
Norwell: 1:14.3
A.Chen89
Postby A.Chen89 » Mon Jun 18, 2012 12:40 am
I think the rears are definitely alot harder than the front, they are a bit of a mission.
Fronts are easy as since you just replace with a sealed unit but the rears you may need some special tools.
dannymac
Postby dannymac » Mon Jun 18, 2012 10:26 am
Hey guys has anyone done the rear wheel bearings yet? About to attempt it myself any advice?
1998 MX5
NC - 2013 - Sports
NB8A - N MX542
Cbr 1000rr 2005
Postby Mr Morlock » Mon Jun 18, 2012 5:01 pm
the usual thing is replace wheel bearings if there is a fault otherwise don't. Read a workshop manual and have the right tools the time and the facilities. There are lots of sources for bearings in Au like Yuge linked. Go to a source and get a quote for parts. Ordering from an equivalent lists can be a trap for getting the wrong item.
Timmeh
Postby Timmeh » Mon Jun 18, 2012 7:33 pm
as i don't have a press an have learned that the bearings are sealed I got a quote from APA $250.
Norwell: 1:14.3
Postby Mr Morlock » Mon Jun 18, 2012 9:41 pm
timmeh you are doing alright - looks like you are on a roll.
Caffeine
Postby Caffeine » Tue Jun 19, 2012 10:57 am
MX5 rear wheel bearings are the same as 323 front wheel bearings :)
MX5 front wheel bearings are sealed hub units. They are very easy to replace (10 minutes a side)
Postby manga_blue » Tue Jun 19, 2012 11:45 am
Flat spotted tyre! Take the wheel off and check it out closely around in good light. Or else rotate it with a front wheel and notice how the faulty wheel bearing moves with it.
Timmeh
Postby Timmeh » Wed Jun 20, 2012 6:39 pm
Went down to book my car to get to them until monday.
I wont be able to drop the car off then.
Apparently (as I was told) the 1990 Mx5 Bearings are different to the Eunos Roadster ones. is this true?
back on the search. :frown:
Norwell: 1:14.3
Users browsing this forum: No registered users and 406 guests
