NC pulling to side
- Regie
- Vehicle: NC - V8
NC pulling to side
Ive been noticing a strange problem the last few days.
When I'm crusing down the motorway, then put my foot on the throttle the car seems to want to steer to the right.
It only happens when the car is under power. There are no strange noises or anything happening out of the ordinary.
I had a wheels alignment a few months ago on the club day.
Any ideas? I'm going to have a look under the car today sometime
- Vehicle: Non MX-5
Re: NC pulling to side
check the tyre pressure on the left side front. if that is correct, then start looking at every bolt and bushe under the car.
- JBT
I'd suspect rear suspension. The settings could be wrong (you should have noticed it after the alignment though) or something like a lower control arm or link has become loose causing variable toe or thrust angle.
Unsure if same issue, but recently my front sway bar moved across, causing the car to pull left..
Regie, it's the turbo kicking in ;)
Check under the front wheel arch for a wombat, kangaroo or pedestrian.
- Regie
- Vehicle: NC - V8
All fixed. Was a flat right rear tyre....a tad hard to diagnose after 2 14hr nightshirts....I was a bit of a zombie when I posted the original thread
- Vehicle: Non MX-5
Good to hear it's all fixed. Those nightshirts totally stuff me also. I was close with the flat tyre, just got the wrong opposite corner. Now the question is, why was it so flat to cause issues?Regie wrote:All fixed. Was a flat right rear tyre....a tad hard to diagnose after 2 14hr nightshirts....I was a bit of a zombie when I posted the original thread
- Regie
- Vehicle: NC - V8
project.r.racing wrote:Good to hear it's all fixed. Those nightshirts totally stuff me also. I was close with the flat tyre, just got the wrong opposite corner. Now the question is, why was it so flat to cause issues?Regie wrote:All fixed. Was a flat right rear tyre....a tad hard to diagnose after 2 14hr nightshirts....I was a bit of a zombie when I posted the original thread
Had a nail in it, slow leak I assume...when I saw it this morning it had 6psi in it....I'm ather lucky I didn't damage the rim down the motorway heading home from work this morning.
Got it plugged, all good now. I was thinking diff bushes, broken ppf... $20 fix and it's as good as new
Cheering, we need a catch up early July?
- Regie
- Vehicle: NC - V8
Hjt wrote:all good now. I was thinking diff bushes, broken ppf... $20 fix and it's as good as new
Yes! When's the July club track day? Keen as mustard to get out there
- JBT
Regie wrote:Got it plugged, all good now. I was thinking diff bushes, broken ppf... $20 fix and it's as good as new
Good result. It would have been causing similar issues to rear suspension problems - luckily it was the cheapest thing on the rear suspension.
- Regie
- Vehicle: NC - V8
JBT wrote:Regie wrote:Got it plugged, all good now. I was thinking diff bushes, broken ppf... $20 fix and it's as good as new
I reckon, I didn't want to delay my 4.1 install and flash tune
- Guran
- Vehicle: ND - 1.5
29 July. You WILL be there right? No teasing now.
- Regie
- Vehicle: NC - V8
Guran wrote:29 July. You WILL be there right? No teasing now.
Thanks Bryan, I'll be there!
Users browsing this forum: No registered users and 313 guests
