Hi, I have finally got the timing belt over the pulley. Haven't tightened the crank bolt or the torqued the two pulleys but here is an image of the marks on the cam sprockets. The crank sprocket is at the TDC position.
Below that is what it looked like before I took the old belt off. I also have not turned the crank two revolutions so things might change but these marks look good to go. I have followed the the lower markings on the sprocket face along the tooth and it lines up on both sprockets. I'll tighten the the crank up tomorrow. I am planning on using loctite and want to be able to take it off again easily if there is any problem
NEW BELT:
AND
THE OLD BELT:
An update also on the bolts for the crank pulley. I ended up getting them from Pick-a-Part. I looked among the Mazda and related cars and found that the old 90s Ford Festiva crank pulley has identical bolts (it makes sense since its a Mazda engine).
