charlie's na6
charlie_91
Re: charlie's na6
Postby charlie_91 » Fri Jun 01, 2012 9:00 pm
im doing the 23rd of June in a couple of weeks :) then early July theres a couple at qr that ill do to :)
PaulF
Re: charlie's na6
Postby PaulF » Fri Jun 01, 2012 10:27 pm
charlie_91 wrote:5th is the highest i can take turn one so i need to get back into that.. and i dont usually like shifting down at speed because it unsettles the car :( Might have to though.
Do you heel-toe on downshifts?
Re: charlie's na6
Postby NitroDann » Sat Jun 02, 2012 12:15 am
NitroDann wrote: Maybe practice your pedals
charlie_91
Re: charlie's na6
Postby charlie_91 » Sat Jun 02, 2012 12:24 am
Yeah in that first session I wasn't heal toeing just driving normal. I was using a different line. Through a few of the corners so I was more concerned with getting that right. In the second session I was heal toeing but in saying that I we only out there for two laps so it didn't give me much time to practice :(
Next time
mrpham
Re: charlie's na6
Postby mrpham » Sat Jun 02, 2012 1:25 am
Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake!
Current Forum Specials!
Smokinscotty
Re: charlie's na6
Postby Smokinscotty » Sat Jun 02, 2012 1:45 am
NitroDann wrote: Maybe practice your pedals on the street too. i always find If you can do it first time everytime on the street then you can on the track without even thinking about it.
Looks quick.
Experience is greater than any go fast mod you can bolt on! Although can be tricky in light sensible street braking, it's retraining your brain on how you downshift. I've always found it easier when you brake late and hard, but even h-t the landcruiser while trawling to work using minimal pedal pressure but keeping a steady foot while swiveling. It's all experience and it all counts.
Pham, I lol'd so loud I just woke up the missus!
So lets go!
plohl
Re: charlie's na6
Postby plohl » Sat Jun 02, 2012 5:05 pm
Looks quick.
i learned to heal-toe in a 60 series and my first car (renault!). I have always found low speed stuff in traffic is much harder to get the feel for.
You'll get the hang of it. Also, saw your new catch can today charlie - Should be sufficient :)
plohl
charlie_91
Re: charlie's na6
Postby charlie_91 » Sat Jun 02, 2012 6:24 pm
Haha yeah I think so :)
BitRusty
Re: charlie's na6
Postby BitRusty » Mon Jun 04, 2012 1:11 am
think i just drooled over that acceleration :)
2005 SE
2002 SP Track
1999 Track (for sale)
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Jun 04, 2012 10:45 pm
So update,
Picked the car up today.. Got a custom air oil seperator/catch can made up .. Its actually to parts in the one tank sort of thing.. hard to explain but its pretty cool. Should solve my problems for sure.. Will need to test it again at Lakeside Raceway in a couple of weeks so we will monitor how much oil gets in there and then go from there.. If its necessary for a drain that we will do that, also running a line off the other side of the valve cover to.
But like i said, still need to test. Its not something u can really test on the street unfortunately :P
heres a pic :)
Once i picked the car up, drove 80km to a mates place and dropped it off for some fabrication work ;) This will be epic but i wont spoil it :D
Also chucked it on stands and took the wheels off to get re done :) extremely keen.
Re: charlie's na6
Postby Lokiel » Mon Jun 04, 2012 11:22 pm
I'm envious of all that space you have in your engine bay that allows you to easily move your catch can from the front of the engine bay to the rear. In my SE, engine bay space is at a premium so options are few and far between.
I'm enjoying your build progress so keep it up - it's giving me some "bad ideas" though ($$$).
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Jun 04, 2012 11:28 pm
haha all this space comes at a cost.. i no longer have window washers or windscreen wipers for that matter :P thank god for rainex :D
plohl
Re: charlie's na6
Postby plohl » Tue Jun 05, 2012 12:43 am
Looks good man! Hardly even notice its there.
plohl
Hjt
Re: charlie's na6
Postby Hjt » Tue Jun 05, 2012 9:21 am
Looks great. Does it have baffles inside or is it two tanks combined?
I'm envious of your time or time management skills, I have had bushings under my table since early January.
16bit
Vehicle: NB8A - Supercharged
Re: charlie's na6
Postby 16bit » Tue Jun 05, 2012 9:59 am
i have had mine for over 2.5 years!!!!
