Problem solved. Plug with smaller gap did the trick.
thsnks tim
Diagnosis
- Novice1
- Steampunk
Re: Diagnosis
You need quality colder plugs.
Didn't anyone from any of the recent tuning shops replace them? Or at least suggest it? I assumed they did as it's a basic upgrade that corresponds with higher boost mods.
- timk
Re: Diagnosis
'zoomzoom' and I have been using BCPR7ES copper spark plugs successfully for boosted applications. They come gapped at 0.8mm which should be good.
- Vehicle: NA6 - Turbo
Re: Diagnosis
saboteur wrote:'zoomzoom' and I have been using BCPR7ES copper spark plugs successfully for boosted applications. They come gapped at 0.8mm which should be good.
im pretty sure thats what i run in my car too. no messing around with gapping plugs. just buy and chuck them in.
Also i am surprised that people dont do something to address the Volt drop to the coils from the stock wiring loom. the voltage getting to the coils is pathetic.
i am going to run a heavy wire from my alternator via a relay mounted next to the ignitor. that way the coils will get all the voltage they deserve.
- A.Chen89
- Vehicle: NB8B - Turbo
Re: Diagnosis
not living up to their full potential eh?
- PaulF
Re: Diagnosis
A.Chen89 wrote:not living up to their full potential eh?
Ohm my goodness, that was terrible.
Re: Diagnosis
Hey Ron,
Just wanted to ask, what plugs did you end up going with and what gap was the car happy at?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
