OK, so judging by this -
It seems obvious why autotune destroys the driveability of the car
I have played around for about an hour now in LM programmer and i believe i have everything set right.
Clearly i do not though.
The Analogue gauge and TunerStudios are about .5 different, and LOGWORKS shows that i am over 1.5 points different.
Explains why it idles so well at what i thought was 15
Is there somebody that can help a fool like me out?
Calling all LM PROGRAMMER Experts out there!!
- Dweezle
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- zossy1
Mine consistently shows a 0.2 AFR difference between actual AFR (displayed on LC1 gauge) and Tunerstudio. This is a known fault, and provided you allow for it by setting your target AFRs 0.2 low across the board) you should be apples.
More variance than that and I would suggest you either have the wrong wideband settings in Tunerstudio, or your WB requires a recalibration.
Or your LC1 and/or sensor is toast...
- Dweezle
Re: Calling all LM PROGRAMMER Experts out there!!
Thanks Zos.
I am recalibrating the LC1 now.
Then i will play with the settings again to see if i can get LOGWORKS and my gauge to at least match closer than 1.4 difference.
If you know off hand, could you let me know what settings your kicking out of the LC1 to the MS?
It matched the settings from my gauge to the MS output and they are seeing similar, about .4 difference sometimes.
Thanks mate
Thanks mate
Jeremy Clarkson
Jeremy Clarkson
- Dweezle
Sorted!!!
Well mostly. :grin:
I am now reading within .2 on my analogue gauge and logworks
I am still almost .5 difference between analogue and tunerstudios.
But that's workable..
Hey Zossy, or anyone, is there a easy way to offset the wideband in tunerstudios??
That way i don't need to use my head in the Target Afr table.
Well mostly. :grin:
Jeremy Clarkson
Jeremy Clarkson
- zossy1
There is a way, but IIRC it is not easy. Sorry, I don't remember off the top of my head what the right WB settings are, pretty sure it is Innovate LC1 0-5V but don't quote me
Check msextra and mt.net for more info on the Tunerstudio AFR variance and the fix
- gslender
Being a fairly good programmer of megasquirt, what issue are you having? I don't believe there is any LC1 calibration issues, but if there is, I'm happy to fix it.
G
G
Dweezle - How do you have the earths for your LC1 and Megasquirt wired? It sounds to me like you might have a ground offset problem.
The LC1 manual has a useful section on wiring, and the importance of proper grounding in particular.
Ultimately you should have both the LC1 and Megasquirt earths attached to exactly the same point, with the same length wire. This goes for your analogue gauge too.
In practise, you should be able to get away with the LC1 / Megasquirt / Gauge earths just connected together at some point somewhere close to the Megasquirt.
With your setup currently, the only number I'd trust (after a free air calibration) is the value being displayed in Logworks via the LC1 serial connection.
Dave.
Dave.
Zoomtherapy wrote:In practise, you should be able to get away with the LC1 / Megasquirt / Gauge earths just connected together at some point somewhere close to the Megasquirt.
Sorry, just to be clear, this is bad advice.
Thinking things over, you proabably don't want the Megasquirt earth taking the heater current...
Best scenario is to have LC1 / Megasquirt / Gauge earths all grounded together at the block / head.
- Dweezle
Thanks for the reply.
Not using it anymore.
But in case this helps someone out down the track.
I was using the grounds and power for The lc1 from the megasquirts Db15 connector.
Braineack built it that way so i assumed that was fine.
I seemed to have almost an exact whole point richer than what was being displayed on a gauge.
So i just tuned from logworks and used the gauge as a guide during driving.
Jeremy Clarkson
Jeremy Clarkson
Users browsing this forum: No registered users and 44 guests
