charlie's na6
Re: charlie's na6
Looks good.
The only thing I can think is that the rear seems relatively tame compared to the front.
Any plans for the rear bar at all?
Your old diffuser would suit perfectly.
Re: charlie's na6
Thanks heaps for that. I wasnt sure about the angle so just left if at that. Next time ill reduce the angle
16bit wrote:hey mate photos looks great.
Those times are really good for your first time at the track and on street tyres.
you might want to run your wing at a much shallower AOA (angle of attack). 3D element wings like to be run at 0-10 degrees for the main plain. at the angle you have yours it will be giving heaps of drag and probably less downforce then at 5 or so degrees.
Here are a few articles.
http://www.aprperformance.com/index.php ... iew&id=183
http://aprperformance.com/index.php?opt ... &Itemid=44
- 16bit
Re: charlie's na6
no worries man. i did the same thing and just found i was slower down the main straight the first time.
really looks the bizz on track!!!
Re: charlie's na6
update:
So managed to get a couple of videos..
Here u go
Short Clip
http://www.youtube.com/watch?v=Ga7clABzkBU&feature=plcp
Long Clip
http://www.youtube.com/watch?v=Cr8zrLWYMrc&feature=plcp
And heres a couple of pics.. Right now the car has been raised a little, more cut out and canards and wing is back off. I remounted the fender as u can see in the first pic it kinda unhooked and just flapped in the wind like a boss
Here u go
Short Clip
Long Clip
- Vehicle: NA6 - Turbo
Re: charlie's na6
wastegate sounds nice!
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Re: charlie's na6
Yeah it does
the loud exhaust will be on for the next track day so should be good
Hoping to have a go pro by then too
- tobias
Re: charlie's na6
What are the chances of getting some pics on how you mounted the canards? Car looks great
Re: charlie's na6
I'll see what I can do.
As for an update my indicators rocked up today
yay haha.
Pretty much spending done for a long while haha. Just gonna try and get as much track time as possible.
If figured all I want is 160rwkw for daily and track and then have a switch wired in for high boost. Which I want to be at like 220 rwkw just to have straight line fun
- plohl
Re: charlie's na6
it'll be interesting to see some lap times on full boost and low boost.
Awesome build dude. Serious hard on material haha.
Oh, have you installed the bias adjuster yet?
plohl
plohl
Re: charlie's na6
i dont think there would be much gains if i had it on high boost with current brakes/tires.
Nar i havent had time to do it yet.. But that reminds me.. i hope i remember where i put it
Have you done urs yet ?
- plohl
Re: charlie's na6
Yeah - you might get away with different pads - ultimately comes down to your tire though....
Nat, i have been lazy - plus there is now where around to really test it.
plohl
plohl
Re: charlie's na6
Update:
So this last week the tune has been getting touched up by GT auto and now makes 180 rwkw on 1 bar
Havent dríven it yet but will shortly
Re: charlie's na6
180rwkw! Thats 235rwhp, Thats stock bottom end material, Crank It Up!
Re: charlie's na6
not going for all out power.. This is street and track. When i get a dual stage boost controller ill have a switch for 22psi
Re: charlie's na6
NitroDann wrote:180rwkw! Thats 235rwhp, Thats stock bottom end material, Crank It Up!
Realistically, any idea what the max usable rwkw figure is before you need to add weight in the boot?
Like most guys, I'm impressed by big numbers but I'm also not interested in wasting money on unusable power modz.
Users browsing this forum: No registered users and 18 guests
