Guage Rings
jlo8872
Guage Rings
Postby jlo8872 » Wed May 09, 2012 10:26 am
Hi,
Probably already asked and answered but; how hard is it to fit guage rings to an NA8 instrument cluster?
J.
1997 NA8 BRG LE.
"You're a pack of Arseholes"
- Jim Richards responds to a booing crowd of the 1992 Bathurst 1000.
BadBong
Re: Guage Rings
Postby BadBong » Wed May 09, 2012 10:34 am
It'll take you about 5mins to take the cluster unit out. There's been quite a few write-ups of this in the forum so have a quick search ;)
After that, it's a matter of removing the clear plastic at the front and then replace the gauge rings with the aftermarket ones. Some glue will be required.
Wear gloves if you don't like leaving any marks.
Re: Guage Rings
Postby hks_kansei » Wed May 09, 2012 11:11 am
BadBong wrote:It'll take you about 5mins to take the cluster unit out. There's been quite a few write-ups of this in the forum so have a quick search ;)
NB yes, on the NA I think it's a little more complicated.
I think on the NA the clear screen is glued to the black gauge bezel, where the NB the clear part just clips on.
91 Malibu
Re: Guage Rings
Postby 91 Malibu » Thu May 10, 2012 4:18 pm
I have done this to both the NA's I have owned 2 things you need to be careful with.
If you still have the original meter surround chances are high it will be very brittle,on my 1st NA it fell apart in my hand with very little force when I was taking it off.
Removing the clear plastic gauge cover can be tricky, I used a sharp knife to cut the glue, take it slow & don't pull at it unless you have run the knife through most of the glue.
Well worth the effort in my opinion the finished job looks great.
Cortina MK11 GTL
Mazda 3 SP23 Daily drive
Re: Guage Rings
Postby hks_kansei » Thu May 10, 2012 4:23 pm
Another hint from my model car making days.
Don't be tempted to use superglue to put the clear plastic back on.
Superglue fumes will basically stick to the clear plastic and make it go all ugly and opaque (and not just where the glue is, basically anywhere the fumes reach as it dries)
