Caliper compatibility (mx5 - 323 - 626)
Gladiator
Postby Gladiator » Sat Apr 28, 2012 8:36 am
Can anyone tell me if the rear brake calipers on an NA6 are compatible with the 323 or 626 calipers of the same era?
Andrew :?
Re: Caliper compatibility (mx5 - 323 - 626)
Postby hks_kansei » Sat Apr 28, 2012 9:55 am
Good question.
I think the 323 had drum brakes at the rear right up until the late 90s (exceptions being the sporty models)
626 I'm not sure.
Gladiator
Postby Gladiator » Sat Apr 28, 2012 11:38 am
You're right. I've just got back from the wreckers who told me they were a match. THEY ARE NOT.
Postby manga_blue » Sat Apr 28, 2012 4:56 pm
I've got an early nineties BG Astina 323 sitting in the shed. It has 4 wheel discs but the calipers and pads are different from any MX5 that I've. seen.
Steampunk
Postby Steampunk » Sat Apr 28, 2012 8:37 pm
You can use brake-pad listings to help ascertain close compatibility.
Don't forget that Ford shares many components (Capri, Laser, Telstar etc)
Hjt
Postby Hjt » Sat Apr 28, 2012 11:42 pm
I know the rear calipers on the laser are a direct match with the na6.
Tight wad racers
Postby Tight wad racers » Tue May 01, 2012 12:04 am
Very interesting,
which model laser.
cheers
Hjt
Postby Hjt » Tue May 01, 2012 12:58 am
dunno, call mx5 mania forum sponsor. They have a new loan car, a laser, and thats where the news came from.
project.r.racing
Postby project.r.racing » Tue May 01, 2012 8:49 am
A BA 94-98 mazda 323 astina (1.8, not 1.6) share the same rear rotor and pad with a na8/nb8, so assume the caliper is the same. I will add a side note to this that the 2.0 V6 version has the same rear rotors+pads, but the rotors are 5x114.3 stud pattern and the hub size is 67mm.
A BG 90-94 (1.8 DOHC, not 1.8 SOHC/not 1.6) share the same with NA6 from memory, but I really haven't delt with BGs or NA6s to confirm.
BG = KF/KH Laser
BA = KJ/KL Laser
datfreak
Postby datfreak » Wed Aug 12, 2015 9:22 pm
project.r.racing wrote:A BA 94-98 mazda 323 astina (1.8, not 1.6) share the same rear rotor and pad with a na8/nb8, so assume the caliper is the same. I will add a side note to this that the 2.0 V6 version has the same rear rotors+pads, but the rotors are 5x114.3 stud pattern and the hub size is 67mm.
BG = KF/KH Laser
BA = KJ/KL Laser
How about the front disc/caliper? do the ba/kj fit our na?
project.r.racing
Postby project.r.racing » Thu Aug 13, 2015 3:08 pm
nope different.
Users browsing this forum: No registered users and 156 guests
