critique this setup
vrmmmpshhh
critique this setup
Postby vrmmmpshhh » Fri Apr 27, 2012 2:41 pm
hi guys i bought the TD04 turbo kit on these forums and hope to have it in on 1990 NA6 roadster within the month. I will keep it at the stock boost of 7psi and very sure that i will NOT want to go more than that. Car isnt a daily driver just something to have some cheap fun in. I bought it in Japan when i was living there so it has sentimental value and will just be garaged if i ever stop using it.
kit will eventually comprise of
TD04 9B turbo which i know is small
starion over the radiator intercooler
2.5inch exhaust
NB 1.8 injectors when i find some
NO BOV
wideband 02 sensor
I do not want to get an aftermarket ecu for the small power upgrade that im looking for so im tempted to go for the jaycar DFA for fuelling and possibly the jaycar kit for the ignition too.
fuel pressure regulator??? any suggestions, hopefully something i can pick up locally.
02 clamp - is this really needed for the factory ecu?
Any help would be appreciated and before anyone lays it into me i have been reading like mad on all the forums but want an Australian perspective. I know of all the parts readily available from the states but at the end of the day i'd rather keep my money in Oz.
Re: critique this setup
Postby bruce » Fri Apr 27, 2012 2:51 pm
You need a BOV unless your car is an automatic.
Without one, when the throttle closes on gear changes, the pressure goes backwards towards the turbo. This stalls the turbo which can damage it.
spaztikcamel
Postby spaztikcamel » Fri Apr 27, 2012 3:10 pm
the actuator on that turbo was 6psi.
bov is not necessary but nice to have.
the 1.8 injectors will do fine if your worried about af ratio take to dyno and get them to do a quick log with their wideband (should cost around $60) if its not too lean your golden.
You may need a fpr I never ran one but I never used my wideband until I got megasquirt.
anyone feel free to correct me.
hopefully Nitrodann chips in as he'll have the best advice.
Postby hks_kansei » Fri Apr 27, 2012 3:16 pm
I would have thought you'd need a wideband regardless?
If you're changing the AFR (via standalone ECU or piggybacks) you'll need to know what the changes are actually doing.
No point installing the DFA then sitting there and making a pure guess and saying "umm....... add fuel? let's just randomly select 6 as a number to input"
Unless you do it the old fashioned way and after each drive check the spark plugs to see how it's running?
I don't actually know, I'm just speculating.
vrmmmpshhh
Postby vrmmmpshhh » Fri Apr 27, 2012 3:29 pm
i will definitely get a wideband. Im not used to tuning my cars this way, on my stock FD i just chucked in a powerfc and it netted 197rwkw so i left it.
as for the BOv i think they are wank and id rather not draw too much attention to the car which is already hard. I dont want the extra plumbing to close it back into the intake too.
spaztikcamel
Postby spaztikcamel » Fri Apr 27, 2012 4:07 pm
hes got a cast mani and 2.5" downpipe to suit
spaztikcamel
Postby spaztikcamel » Fri Apr 27, 2012 4:08 pm
what the hell just happened to bootz' reply? I reply and all of a sudden vanished ninja edit at its finest.
Postby bruce » Fri Apr 27, 2012 6:25 pm
A BOV is a fundamental item. Without one, at the least, it will slow your turbo (making your low boost set up even slower).
It's not a wank item - every factory manual turbo has one. Just plumb the vent back into the inlet thus eliminating/minimising noise.
Postby NitroDann » Fri Apr 27, 2012 7:25 pm
You need to set static timing to 6 degrees and run 11.5:1 afrs or richer in boost. A jaycar DFA isnt really recommended but it will work. You shoiuld also adjust the spring in the afm to help add extra fuel. using the wideband all along to check its at least 13:1 at 0psi down to 11.5 to one at full boost.
A BOV isnt 100% necessary but it will quieten down the car and help with performance on gearshifts.
Greddy kits are asthmatic at the best of times.
I guarantee you will want more.
It will spool at 4000rpm or later and run out of puff at 6500rpm.
honestly.
Postby NitroDann » Fri Apr 27, 2012 8:00 pm
Dont forget it wont have enough fuel stock so injectors or (better) use a fuel pressure reg.
bootz
Postby bootz » Fri Apr 27, 2012 9:15 pm
spaztikcamel wrote:what the hell just happened to bootz' reply? I reply and all of a sudden vanished ninja edit at its finest.
Sorry mate, thought he only had the turbo, reread the setup so my reply was irrelevent. :lol: :mrgreen: :lol:
vrmmmpshhh
Postby vrmmmpshhh » Sat Apr 28, 2012 10:18 am
thanks for the help guys. ive decided that i will probably use the jaycar DFA for fuelling and get the bipes acu for the ignition as its a simple unit that seems to do the job well.
the other question i have is the kit comes with a td04-9b turbo which is from a very old mitsubishi colt its the smallest of the TD04 turbos, it has the triangle exhaust flange, does anyone know if the other triangle flanged TD04 models fit (wrx etc)? I really hate how the TD turbos are named, there seems to be a whole host of exhaust housings available, greddy kit uses a garret flange ffs.
vrmmmpshhh
Postby vrmmmpshhh » Sun Apr 29, 2012 10:12 pm
i just bought a greddy emanage blue with the na6 harness to do the piggybacking.. was $340
Postby NitroDann » Sun Apr 29, 2012 10:16 pm
Better than a DFA by far, but only 150 bucks short of a proper ecu (a megasquirt).
vrmmmpshhh
Postby vrmmmpshhh » Fri Jun 22, 2012 12:10 am
kit is being installed right now. have dummied up the manifold and turbo but i cannot see how i will run the hotside cooler piping. i have AC and PS and there is crap everywhere on that side of the engine bay. the starion intercooler wont even fit because the AC canister is in the way.
