Bizi gets Mrs Bizi a Clubman!
Bizi
Re: Bizi gets Mrs Bizi a Clubman!
Postby Bizi » Sat Mar 17, 2012 9:33 am
Coming soon.
Not sure if I can mount these to the NA8 base, hence my chasing of the NA6 base.
Someone has posted a DIY on mounting these on the NA6 base and it looks like it works well. I've seen similar mounting on a 911, also using the OEM base. :) Sebring Mach 1.
Some NA owners have fitted the M2 1028 version, repro Japanese versions and maybe even the DIY using OEM mounts. Anyone used NA8 bases?
I'd paint the base gloss black, so any NA6 base will do!
For Babalouie or anyone else interested. 911 Vitaloni Sebring fitment pics:
https://picasaweb.google.com/udoreising ... loniMirror
Bizi
Postby Bizi » Tue Mar 20, 2012 11:24 pm
Thanks to Dino.
Does anyone have a set of old NA6 mirror bases? Mirrors don't matter!
Most of the XY GTs at PITS on Sunday had the tiny GTHO style mirrors, but they really are VERY small. I asked the owner of this car and he said the XY GT rearview mirror is great but the GTHO side mirrors are absolutely useless!
bootz
Postby bootz » Wed Mar 21, 2012 12:10 am
Love all this retro fashion stuff.
Bizi
Postby Bizi » Mon Apr 23, 2012 8:09 pm
Since I put this on wassup's garage thread I'd better leave him alone and obsess on the M2 1028 here. :)
Since there's one for sale right now in Japan.
Anyone want a cheap and extremely rare M2 1028?
Modded as a race car - PLEASE PM! Hopefully it comes here!
Since it's set up already as a circuit racer, with hardcore porn race engine mods, it's worth a look!
It would be pretty hot to have a rare M2 1028 as your race car. :D
A genuine M2 1028 in white (translated link).
http://www.importmonster.com.au/view?ur ... jpg&title=
Anyone interested in the car?
Note that this auction car's look is a bit wrecked since the owner sold off the Vitaloni/M2 1028 mirrors! wtf?
itbs!...or 'H6 year M 21,028 roadster 4 connected throttle'.
I've not seen a white NA M2 1028 ID tag before, have you?
The translation's terrible but it seems to be heavily modded to be a circuit racer, with lots of internal engine mods as well as the Rx& FC3S 4 pot calipers and bigger rotors. Hence the wheel change.
Quite a package, so enjoy the read.
You might be better able to translate than me.
M2-1028.
...4 connected you exchange to the throttles, control the computer, with the F [kon] V professional of HKS.
...the owner when overhauling... piston for race/lace... EX high cam of HKS... inserts the strengthening bubble spring ... piston and the connecting rod the weight adjusting...crankshaft we have heard that the balance [do] [ri]...lightweight flywheel and the strengthening clutch.
Furthermore, rammer foot [sutenresumahura], you exchange the catalyst to [metaritsutokiyataraiza], take official recognition. Because the piston of big bore size for race/lace was inserted...displacement has risen, but as this has taken official recognition, there is statement in car verification. ...the oil cooler of the radiator and one type has been attached in order to make management optimum. Furthermore, the core is the aluminum make of bulk. ...brake, 4 pod ... FC3S on the front ... large diameter rotor, the large diameter rotor is installed even on the rear.
Also [burekibaransa] is installed. Front and back adjustment type we install also LSD in the stabilizer.
Suzuka it ran also the circuit and the TI circuit, but it could enjoy rather.
Presently C ring type height adjustment suspension of [orinzu] has been attached, but pyro of the upper mount the rice increases exchange. In present specification, it depends on also the tire, but or the high-speed circuit it is quick the straw, the way you were moved.
...owner full has overhauled travel distance, in addition because I overhauling the head after only the 2000 am running in 2007, you think that it is from now on. Because the front owner one time has exchanged also the body, it is thought as the thing which is not problem even in body rigidity and the like. However because, the body changing is done, because we have become authority carving, restoration history makes unclear. If car it can have verifying with verification, you understand, but it is genuine M2. Big the scar, there is no dent. Because genuine having tried to re-cover, removing, we keep the seat, we transfer together the occasion where it transfers the car. Large amount the commodity, inside thing and the engine whose remodelling place is many we request present car verification concerning the information from the front owner.
Bizi
Postby Bizi » Wed Apr 25, 2012 4:39 pm
Interesting post here on a kit car forum.
Anyone here born in the 70s or before might have heard of the Purvis Eureka.
http://www.sterlingkitcars.com/members_ ... ml#post614
Same car as that, I think and this post compares a few options for putting in projector headlights. Something I'm keen to explore, too.
http://www.sterlingkitcars.com/members_ ... ts-ice.jpg
These are not going to fit, but I was thinking of whether they could be made to fit in our NAs.
Too big for this car, so waay too big for our car!
Image Integra headlight. Sitting on the ground under this kit car.
Bizi
Postby Bizi » Wed Apr 25, 2012 6:56 pm
While the Integra lights may not fit, there's always the option of RX7 (FD?) lights, with a xenon projector retrofit, like this:
http://www.rx7club.com/showthread.php?t=947068
Nice, huh?
Off to SYD...
Bizi
Postby Bizi » Mon May 21, 2012 8:32 pm
A novelty spotted on the Japan webs.
Get what is probably an eXXXtremely rare MX5 accessory.
Just don't think about the eXXXtremely inflated price. It indicates it's on heck of a buy, I guess... The Japlish text needs a better translation.
It's clear this is RARE!
http://www.importmonster.com.au/view?ur ... /u40911527
Roadster M 21,028 emergency top NA8C
M 21,028 option part Emergency top
The roadster and emergency the top for M 21,028 (the simple top)...
...even one time you have not used because and, there is no either instruction manual, you do not understand well...
Because you attached the fastener which is attached to the weather strip section to one time 1028, there is the soiling
As for the substance you think that entirely it is clean,
The rear screen the protective agent seems that something is painted
According to the place where you hear either 100 units are not made, it seems, because is, it is rare in that appearance
When if anything it probably is [korekutazuaitemu] from utility?
Here it is!
It might look like this.
This looks funny. Looks like a M2 1028.
Maybe this is helpful for people keen to do a bikini top (even a 2 piece top like this M2 1028 one) that utilises the BD or MX5+ roll bars.
Postby Regie » Wed Jul 11, 2012 7:35 pm
