Andrew's '93 NA6 - KL V6 swap
- 16bit
Re: Andrew's '93 NA6 - KL V6 swap
fine craftsmanship.
- Beelzeboss
- Vehicle: Non MX-5
Thanks very much 16bit.
Today I cut most of the hoses to length and made another vacuum fitting. I also cut up the stock radiator hoses to find a shape which would fit, it looks pretty simple, just a 45 degree bend and a 25 degree one.
- Sean
Love this!
One of the coolest threads on here!
Can't wait to see this thing powering down the road! Awesome build mate.
STOP SHOWING THIS STUFF:
- you're making me want to go out and buy that lathe even more
Seriously jealous!
Great work, please keep it up, I'd hate to see this project fall by the wayside.
Seriously jealous!
- Bizi
Andrew, will you be fabricating a 626/Probe/RX7 FC brake setup? The FC 4 piston / VW Corrado 280mm vented rotor setup looks the goods if anyone needs bigger than NA8 and I noticed some people use Probe V6/626 bits, so if you had access to a 626/Probe donor...
http://forum.miata.net/vb/showthread.php?t=301815
OMG this is an awesome thread... makes for weekly if not daily intrigue. Thanks for perservering here for all of us....
Cant wait to see the completed product!
Wanna upgrade mine ;-)
1990 NA, 17" Gmax, Flyin Miata Butterfly brace and Stage 2 Suspension
- Beelzeboss
- Vehicle: Non MX-5
Bizi wrote:Andrew, will you be fabricating a 626/Probe/RX7 FC brake setup? The FC 4 piston / VW Corrado 280mm vented rotor setup looks the goods if anyone needs bigger than NA8 and I noticed some people use Probe V6/626 bits, so if you had access to a 626/Probe donor...
I sold the donor car a few weeks ago and the brakes went with it
Basically since the last update I've just been doing little things on the car. I've made all the oil/fuel/vacuum hoses, wrapped all the wiring, put new exhaust studs on the manifolds, new studs on the inlet manifold for the throttle body and ported out the lower section of the intake manifold.
The biggest issue I have at the moment is that the underdrive pulley STILL hasn't arrived, even though it was shipped from the USA on the 1st of this month. My V-band exhaust flanges and clamp arrived, I didn't realise it was such large diameter. I'm having a tough time finding a spot to put it in the exhaust. I can't have the manifold extend too far back or it becomes impossible to install, but there's very little room for the v-band until you move past the bellhousing... I'll take a few pictures next time I'm working on the car.
I've got a few exams over the next two weeks so updates might be a bit sparse. As soon as the underdrive pulley arrives I'll try to make the 36-1 trigger wheel and get the car fired up. I hope starting the engine will give me the motivation to get it finished ASAP.
- Bizi
Go study, put this to the side a while and you will likely get a nice surprise once the pulley arrives.
Any chance of a get-together for the fire up? You're not far from the MB chocolate shop, right?
- Bizi
One last thing: Once you've bedded in this setup, what if someone offered you the 800M Miller Cycle, supercharged KL-J V6?
Get your car added to this impressive list! I never would have imagined a KL going into some of these Aussie cars!
http://www.offroadvw.net/bajawes/V6_baj ... E_cars.htm
Ben stop filling Andrews thread with your suggestions its so distracting. No harm intended but it breaks up the good read!
- Beelzeboss
- Vehicle: Non MX-5
Bizi wrote:Any chance of a get-together for the fire up? You're not far from the MB chocolate shop, right?
Mmmm, maybe for the second start
Bizi wrote:One last thing: Once you've bedded in this setup, what if someone offered you the 800M Miller Cycle, supercharged KL-J V6?
Mmm, it would be tempting but I don't know if the gearbox could hold the torque. I don't really want to have to upgrade to a 6 spd.
I might email them once the car is done, it would be great to be on that site.
NitroDann wrote:http://www.akilla.net/pics/miata/kliatasale/H42C0779.JPG
Have you seen this car before?
No, that looks epic. Does he have a build log?
- Bizi
Beelzeboss wrote:No, that looks epic. Does he have a build log?
JOYFUL NOISE RACING http://majica.net/JNR/here.htm
First start! http://majica.net/JNR/hurdle.htm
Also a quick feature here: http://www.miata.net/motm/2007/snell.html
You haven't seen the blue Kliata before? I figured anyone who had attempted a KLiata would have found this one, since it seems to get a lot of mentions.
I just found this wiki, which appears to be another, for autocross, with lots of work done.
Destination SSM (by Codingparadox): http://www.destinationssm.com/wiki/inde ... =Main_Page
- Beelzeboss
- Vehicle: Non MX-5
Ah, I didn't realise it was the same car. I've only seen it with the ITB's before. Thanks for the links
- Beelzeboss
- Vehicle: Non MX-5
FINALLY the pulley arrived today! It looks pretty good, though the bolts holding the timing plate already have their heads mostly stripped out. That should make removal fun
Not bad for $35 (+ $42 shipping)
