Engine 1.6
Engine 1.6
Can anyone ID the arrowed part
- Vehicle: Non MX-5
Re: Engine 1.6
An oil outlet.
- Sean
Re: Engine 1.6
project.r.racing wrote:An oil outlet.
I think he means inlet...
- Vehicle: Non MX-5
Re: Engine 1.6
Nope I meant outlet. Since it is between the oil pump and filter. Why an outlet is there I wouldn't know.
Re: Engine 1.6
No.
Its an oil return, an inlet, its often used to return oil from a turbocharger...
No.
No.
- Sean
Re: Engine 1.6
Yep that's what I though.
It's painful to use as an oil return just due to locale.
Not sure such a simple bung cover would deal with oil under pressure too well.
Re: Engine 1.6
Drilling and tapping underneath the a/c bracket (
) on the setup I'm building now.
- Vehicle: NA6 - Turbo
Re: Engine 1.6
I tried use it to vent the block
I ran a hose through a catch tank
After 1 track day i had 2ltrs of oil in the tank
It was pumping heaps of oil out so I closed it up again
Re: Engine 1.6
Be ok if you always ran oval tracks... backwards.
haha
haha
- noddi85
Re: Engine 1.6
I know this is a old post but could it be used as a oil cooler return?
I'm looking at options to setup my oil cooler but also my catch can. As the head has two outlets not sure which one would be best.
Chris
Chris
Sometimes I wonder why i have different taste to others??? Then I realise its because Im not a sheep
Re: Engine 1.6
Yeah it can be used as an anything return.
- noddi85
Re: Engine 1.6
What about a feed for it?
Any ideas?
Any ideas?
Re: Engine 1.6
A feed for what? use a sandwich plate.
Have a look in for sale, APU has a genuine works engineering oil cooler kit with everything you need,
- noddi85
Re: Engine 1.6
Cheers will do.
A feed for the cooler I ment.
Was just thinking of using what the engine has rather then a sandwich plate.
