First time servicing
wiztek
Re: First time servicing
Postby wiztek » Sat Mar 31, 2012 12:49 pm
Thanks all for the offers of help.
Got the sump plug off, replaced with a magnetic sump plug. All good.
Putting the oil filter back on :shock: Could not do it from the top no matter how hard i tried, did a lot better sliding under the car and going through the wheel well. Finally got it on.
Spark plugs next after i get a ratchet set.
Apu
Postby Apu » Sat Mar 31, 2012 1:43 pm
Cameron, I you want to make it easier, use a filter relocation kit..of which, ahem, I'll have a few more available in the next couple of weeks.
slowpoke
Vehicle: 10AE
Postby slowpoke » Thu Apr 05, 2012 5:14 pm
Wiztec, re oil filters.. Ryco Z436 from Supacheap do seem cheaper than buying the original from Mazda (Part 86Y1-14-302AUS) BUT the (2) gasket washes are NOT included with the Ryco product and need to be bought seperately, so keep your old ones to help identify the correctly sized new ones. Apparently, its VERY important to fit NEW gasket washes whenever the oil filter is renewed. Cheers from slowpoke
Postby 93_Clubman » Thu Apr 05, 2012 7:07 pm
slowpoke wrote:BUT the (2) gasket washes are NOT included with the Ryco product
SP, are these sump plug washers?
Postby Mr Morlock » Fri Apr 06, 2012 9:52 am
Buy a workshop manual and an owners manual and check out your library. Also easy to buy publications on line. Sourcing on cost alone is not a good process.
slowpoke
Vehicle: 10AE
Postby slowpoke » Fri Apr 06, 2012 11:31 am
YES! Thanks '93C'man for the correction!
The gasket washes are sump plug washes!
project.r.racing
Postby project.r.racing » Fri Apr 06, 2012 11:53 am
it is not urgent that you replace these all the time. but it is good practice to do so. over time they become flattened and misshaped.
as for say ryco don't supply this washer with their oil filters. no brand supplies a sump plug washer when you buy a oil filter. it is a totally seperate car part.
Postby 93_Clubman » Fri Apr 06, 2012 1:53 pm
Tks for clarification SP - didn't realise sump plug washer was supplied with the OEM oil filter.
wiztek
Postby wiztek » Sat Apr 07, 2012 2:48 am
Sorry can you guys clarify? Are we talking about a washer for the oil pan sump plug? If so, i did put in a new one as i bought a new sump plug (though the previous owner didnt have a washer on it at all..)
Does the oil filter have a washer?
Thanks all!
Guran
Vehicle: ND - 1.5
Postby Guran » Sat Apr 07, 2012 7:02 am
You're all good, wiztek. There's no washer on the oil filter. The above discussion is only about the sump plug washer, which you have replaced.
project.r.racing
Postby project.r.racing » Sat Apr 07, 2012 9:00 am
The oil filter has a rubber seal.
vrmmmpshhh
Postby vrmmmpshhh » Sun Apr 08, 2012 9:22 am
Which you are supposed to oil up before you put it back on.. I also just put my oil filters on hand tight so you can take it off easier next time. Been doing it like that for 16 years every 5000ks no probs.
Gladiator
Postby Gladiator » Thu May 03, 2012 12:56 pm
SNAPON brand sockets drive on the flat of the nut/bolt rather than the points. They work on stripped nuts.
Zcootz
Postby Zcootz » Fri May 04, 2012 3:34 am
vrmmmpshhh wrote:Which you are supposed to oil up before you put it back on.. I also just put my oil filters on hand tight so you can take it off easier next time. Been doing it like that for 16 years every 5000ks no probs.
+1 to that. I've avoided over tightening them because ive been worried about deforming the seal.
On my old rally car I had a hose clamp with a pin that I would tighten onto the filter and that would only allow it to spin a bit before the pin would act as a stop but that was a ford engine with a bit of a reputation of vibrating off oil filters ...
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Users browsing this forum: No registered users and 94 guests
