NB Seat Bolt Thread Size
Luke
Postby Luke » Wed Apr 04, 2012 7:13 pm
Hi Guys
Was making me up a bracket to bolt a fire extinguisher to bolt under the passanger seat bolts, and of course I have cross threaded one of the holes!!!
The bracket changed the angle the seat sat at so of course I bolted straight down, probably didn't help that I did it at night with poor lighting. I'm pretty sure it is only the first 2-3 thread though.
So was wondering what the spec of the thread is.
My internet searching says M10x1.25, but it is always for a NA. I can't imagine a NB being different but just want to check.
Plus the bolts are definetly 10mm wide. So I know the M10 part is correct at least.
Next step borrow a tap, hopefully I will have one at work somewhere, but I don't think we have any that big.
2022 BRZ 10AE
2021 GR Yaris
Re: NB Seat Bolt Thread Size
Postby NitroDann » Wed Apr 04, 2012 7:22 pm
Take the bolt into work/nut and bolt place and ask??
zossy1
Postby zossy1 » Wed Apr 04, 2012 7:23 pm
NA and NB are the same. M10x1.25mm sounds right...
Postby Lokiel » Wed Apr 04, 2012 8:07 pm
zossy1 wrote:NA and NB are the same. M10x1.25mm sounds right...
Confirmed - I had to retap some on my SE and that's what I used.
Tip: ALWAYS hand tighten seat bolts as much as possible first, it's way too easy to strip those threads.
Luke
Postby Luke » Wed Apr 04, 2012 9:01 pm
Yep really easy to strip. The metal is quite soft.
At first I though the bolt was grabbing on the holes in my plate because the holes were only 10.5mm, but yeah.
I've taken the drivers side seat in and out countless times, and finally have to do the passenger and bugger it up lol.
Anyway, thanks for the confirmation, I'll check what I've got available at work, but if I don't have it my dads workplace should have it.
Otherwise off to the tool shop.
Odly the workshop manual I downloaded a while back specifies the torque, the head size, but not the pitch.
2022 BRZ 10AE
2021 GR Yaris
marty085
Postby marty085 » Wed Apr 04, 2012 9:06 pm
Where can I get these bolts with the necessary strength? Any decent hardware shop? I want to replace mine as they are the shallow head variety with tapered edges mentioned in the Miata Enthusiast Workshop Manual as being right b!tches. I have already come close to rounding them so only want to take them out one more time and replace them with something half decent.
Postby NitroDann » Wed Apr 04, 2012 9:08 pm
High tensile bolt shop.
Luke
Postby Luke » Wed Apr 04, 2012 9:19 pm
I rounded my first set on the drivers side using a normal socket after changing the seat in and out multiple times.
I bought another Mazda original set (can't remember the price).
This time they are rounding much slower though, as I am using an actual hex 6 point socket rather than the multipoint one. Just seems to grap the bolt head nicer with the 6 point.
I kept the packet from when I ordered them with the old bolts in them incase I ever stripped one.
The part number is: 9YA0 21079
And it says Made in Japan.
2022 BRZ 10AE
2021 GR Yaris
Postby Lokiel » Wed Apr 04, 2012 10:24 pm
marty085 wrote:Where can I get these bolts with the necessary strength? Any decent hardware shop? I want to replace mine as they are the shallow head variety with tapered edges mentioned in the Miata Enthusiast Workshop Manual as being right b!tches. I have already come close to rounding them so only want to take them out one more time and replace them with something half decent.
With my MAZDASPEED seats, I had to replace an OEM bolt on the rear outside corner of both seats because the OEM bolt head is too large for the brackets - the bolt would have to be forced in at an angle which is BAD.
I found that all the big retail car places, Autobarn, Repco and Supercheap stock the required high tensile 10x1.25mm bolts.
If you round these off then "You're doing it wrong!".
marty085
Postby marty085 » Wed Apr 04, 2012 11:09 pm
Thanks :D I'll check out both Mazda genuine and an auto shop!
Aussie Stig
Stig
Postby Aussie Stig » Wed Apr 04, 2012 11:26 pm
I did the same thing on the pass frt left, these suckers are easy to muck up. :shock:
Luke
Postby Luke » Thu Apr 05, 2012 9:19 am
Bugger, biggest we got at work is M8 for taps, and all our 10mm bolts are 1.5mm pitch.
2022 BRZ 10AE
2021 GR Yaris
Postby Regie » Thu Apr 05, 2012 9:48 am
Nice and close to us Marty
http://mobile.yellow.com.au/external/bd ... xt=unknown
Postby Mr Morlock » Thu Apr 05, 2012 8:59 pm
you buy bolts at a specialist fastener supplier - they can identify the bolt spec including grade etc- they can also supply taps. Mazda should also readily be able to supply a bolt.
marty085
Postby marty085 » Thu Apr 05, 2012 9:11 pm
Cheers! And thanks for the link Regie I'll check it out mate
Users browsing this forum: No registered users and 104 guests
